22899 Discussions
application has been blocked from accessing graphics hardware
jmoun3
Hi, I keep on getting this error when I am running a steam game called Unturned. Pops up after a few minutes or even 20 seconds when I am on a server.
I am using an HP Envy TS 15 Notebook PC, Product # : C8P48AV
I went into my device manager and updated it to the latest install. I even tried using the Intel Driver Update Utility and it said ' A customized computer manufacturer driver is installed on your computer. The Intel Driver Update Utility is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer. ' //
My only graphic driver is the Intel HD 4600 graphic.
AP16
Valued Contributor III
This mean that driver obtained from HP (from site or support DVD) is installed in system. Remove (uninstall) current driver and try Intel driver update utility, or graphics driver directly from
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors
jmoun3
I disabled and uninstalled the intel HD 4600 driver and tried using the Intel driver updated utility but it said no drivers were found. I also downloaded the files from the link you provided but it said the computer doesn't meet the minimum requirements for installing this software..
jmoun3
Well nevermind, I fixed the issue by installing windows 8.1...Damn windows 10!!
Allan_J_Intel1
Thanks for sharing that information.
Allan.
