Avisos
23470 Discusiones
b580 显卡无法打开flow3d cast
starsea
Novato
2.979 Vistas
我的电脑打开flow 3d 是 卡在done reading logic tables (驱动Driver 32.0.101.833),当我换回rx5700时,可正常打开
0 kudos
14 Respuestas
JedG_Intel
Moderador
2.918 Vistas
Hello starsea,
注意,我只能用英支持你。我用网工具翻条回复,因此可能存在一些不准确的翻
To address the issue effectively, please share the information below.
1. What version of Flow3D Cast are you using?
2. Is the issue isolated to Flow 3D?
3. Is ReBAR (Resizable BAR) enabled in your BIOS?
4. If possible, kindly share a short video clip demonstrating the issue.
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
starsea
Novato
2.842 Vistas
你好 Jed G,
我已开启ReRAR
我的问题仅限于flow 3d cast(版本为v5.1 updeta2)
我的问题仅限于flow3d
starsea
Novato
2.836 Vistas
以下是我提供的视频文件与ssu 报告
RandyT_Intel
Moderador
2.736 Vistas
Hello starsea,
I'm contacting on behalf of Jed. Thank you for providing this information - please allow me some time to investigate the issue, and I will post an update here once I complete my analysis.
Randy T.
JedG_Intel
Moderador
2.647 Vistas
Hello starsea,
Thank you for your patience while we analyze all the information. To further troubleshoot the issue, please follow the outlined steps below.
1. Perform clean installation of the latest driver 32.0.101.8331 using DDU
2. Update the BIOS to the latest version 7C35v1R
If the issue continuous to persist, please let me know so we can further troubleshoot.
Best regards
Jed G.
starsea
Novato
2.582 Vistas
starsea
Novato
2.559 Vistas
我已尝试您的方案,问题任然存在
JedG_Intel
Moderador
2.472 Vistas
Hello starsea,
Thank you for your cooperation. Since the issue continues to persist, I’ll review this matter internally. Additionally, I will attempt to replicate the scenario in our test lab to observe whether we encounter the same behavior. This will help us better understand the root cause and work toward an effective resolution.
Best regards
Jed G.
JedG_Intel
Moderador
2.340 Vistas
Hi starsea,
I'm reaching out to gather additional information. Please see the information below.
  1. complete crash dump of the system
  2.  Test the oldest available driver for comparison 32.0.101.8132.
If you have any questions, please let me know.
Jed G.
starsea
Novato
2.254 Vistas
我已尝试您的方案,但问题任然存在
JedG_Intel
Moderador
2.144 Vistas
Hello starsea,
May I know if the same issue is observed when using the older driver available 32.0.101.8132? Please also provide the complete crash dump of the system.
Best regards
Jed G.
JedG_Intel
Moderador
1.983 Vistas
Hi starsea,
I'm following up with regards to the complete crash dump and the result of using the oldest driver available. Please share this information at your earliest convenience so we can investigate further.
Jed G.
JedG_Intel
Moderador
1.890 Vistas
Hello starsea,
Jed G.
starsea
Novato
1.846 Vistas
抱歉,我目前没有时间去测试显卡,希望新驱动早日解决问题
Responder
