23662 Discussions
best performance setting
rrudi2
Hi there im new in here
may i know the best/recommended setting for intel HD 630??
im using default setting but when i tried to play video 720p it seems not satisfy..
my CPU specs is
13-7100, 8gb RAM DDR 2133 mhz, biostar h11mh pro D4
edit:
my monitor is samsung ls22f355
i attached my video sample here
thank you very much
Hello rudinirudini,
I understand you are trying to improve graphics performance by changing graphics settings.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Does the issue happen as well with YouTube videos?
Have you tried different video player and/or different video file?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
rrudi2
Thank u for your reply..
i did it, before i used hd graphic 630 my video looks better. but i have screen tearing and i thought i need to upgrade to intel HD graphic.
but when i using intel HD my screen tearing is gone but the video is worse..
so i think i need to do some setting get best result for the video..
here i attached my computer configuration..
thank you
Hello rudinirudini,
Thanks for the information you sent to me.
We usually recommend using default graphics settings. The graphics controller should be able to adjust graphics settings for best performance.
I would like you to try updating the graphics driver. Please download it from this link https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909 https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909
Once the graphics driver has been downloaded on the keyboard press WinLogo key + r, then type in devmgmt.msc, double click on Display Adapters -> Intel HD Graphics -> Driver tab -> Uninstall -> Select the check box Delete the driver software for this device -> OK, restart the computer, and then reinstall the driver I provided.
Let me know if issue persists or not.
Fred D.
Hello rudinirudini,
I was wondering if you still need assistance regarding the performance settings you are trying to set on the Intel® Graphics Control Panel. In case you still need assistance just let me know.
Fred D.
