23808 Discussions
code 43 on new driver installed
RReyn7
i have uploaded the new windows fall edition and lost my intel HD graphic driver with a code 43. con not connect my second monitor and it has been disconnected and still get this error. any suggestion before i have to uninstall the new windows?
I have repeatedly install the intel driver for the computer... no success on the code 43
AlHill
Tell us about your system so you can get help.
What is the processor model number?
What Operating System?
What graphics do you have?
Provide as much complete information as you can.
Doc
RReyn7
the new updated windows 10 fall edition
RReyn7
Good day sir,
As final updated on this issue, i finally got the driver to work after uploading the new driver on the old windows program and then i still had to reload and recover the new windows update two more times after the driver update.
It finally accepted the driver update...
Thank you for pointing me in the right direction...
Bob
AlHill
Glad you have it working.
Doc
RReyn7
System Manufacturer SAMSUNG ELECTRONICS CO., LTD.
System Model DP700A3D/DM700A3D/DB701A3D/DP700A7D
System Type x64-based PC
System SKU System SKUNumber
Processor Intel(R) Core(TM) i5-3470T CPU @ 2.90GHz, 2901 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. P10KMS.076.140213.XJ, 2/13/2014
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer SAMSUNG ELECTRONICS CO., LTD.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "10.0.16299.15"
User Name BOB-OFFICE\Bob
Time Zone Eastern Standard Time
Installed Physical Memory (RAM) 12.0 GB
Total Physical Memory 11.9 GB
Available Physical Memory 7.90 GB
Total Virtual Memory 14.3 GB
Available Virtual Memory 10.1 GB
Page File Space 2.38 GB
Page File C:\pagefile.sys
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, Disabled by policy, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
RReyn7
Name Intel(R) HD Graphics
PNP Device ID PCI\VEN_8086&DEV_0152&SUBSYS_B091144D&REV_09\3&11583659&0&10
Adapter Type Intel(R) HD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) HD Graphics
Adapter RAM (2,080,374,784) bytes
Installed Drivers igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll
Driver Version 10.18.10.4653
INF File oem25.inf (iIVBD_w10 section)
Color Planes Not Available
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xF7800000-0xF7BFFFFF
Memory Address 0xE0000000-0xEFFFFFFF
I/O Port 0x0000F000-0x0000F03F
Driver c:\windows\system32\drivers\igdkmd64.sys (10.18.10.4653, 3.64 MB (3,811,816 bytes), 5/18/2017 3:11 PM)
AlHill
You can find the latest driver for you HD 2500 graphics here:
https://downloadcenter.intel.com/product/81501 Downloads for Intel® HD Graphics 2500
Doc
RReyn7
still have the same issue after down load...
RReyn7
hello doc,
as update I had to do a "redo" a recovery and go back to the pre windows update release, and all works great.
Up date drive again in this mode and still working awesome.
any other suggestions before i try one more time to upload the new windows upgrade...
Bob
