23789 Discussions
core i7 5th Gen
Unknown1234
Hi
My Laptop is overheating, pleas give me any tips to fix it
ClariceStarling
Valued Contributor II
It's a Dell, right?
ClariceStarling
@Unknown1234  If it's not a new computer, I would clean the dust out of the vents, and if you can open it up, clean out the fan.  Many people have posted before that that fixed their overheating problem!
AlHill
Unless this is a setup for spam, do the following:
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
