23784 Discussions
could not load OpenGL subsystem
Hello.
I'm trying to run an old game based on quake 3 engine and it gives me this message.
I have windows 7 x86, Mobile Intel(R) 4 Series Express Chipset Family, latest driver.
What to do?
This is the log from game:
Heavy Metal: FAKK2 1.02 win-x86 Sep 28 2000
----- FS_Startup -----
Current search path:
D:\Games\Heavy Metal Fakk2\fakk\pak2.pk3 (13 files)
D:\Games\Heavy Metal Fakk2\fakk\pak1.pk3 (2532 files)
D:\Games\Heavy Metal Fakk2\fakk\pak0.pk3 (9610 files)
D:\Games\Heavy Metal Fakk2/fakk
Config: config.cfg
execing default.cfg
execing menu.cfg
execing config.cfg
execing localized.cfg
execing autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\windows\system32\opengl32.dll' 😞 succeeded
...setting mode 7: 1152 864 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@0,0 (1158x892)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...41 PFDs found
...hardware acceleration found
...PIXELFORMAT 6 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
GLW_StartOpenGL() - could not load OpenGL subsystem
