22931 Discussions
dopo aver aggiornato windows a windows 11 / after update windows at windows 11
Thomas1995
italiano : se cambio le impostazioni nel programma intel graphic center uhd, il programma non elabora le modifiche, cioè se alzo la luminosità, non aumenta e si applica a tutte le modifiche, non cambiano
(englis) :
if I change the settings in the intel graphic center uhd program, the program does not process the changes, that is, if I raise the brightness, it does not increase and applies to all changes, they do not change
Jean_Intel
Hello Thomas1995,
We understand you have opened a chat case with us and we will continue to help you through that channel now. We will therefore close this community case. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Best regards
Jean O.
