23660 Discussions
driver intel para software davinci resolve 18
manuelon
hola! uso una pc que tiene windows 10 pro, instalé un software de edición de video y audio que se llama da vinci resolve y me pide un driver open gl de nvidia, pero mi computadora tiene intel, cual es el driver compatible?
gracias
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
