23726 Discussions
driver per PCI Device 27D8
CPozz
Buongiorno, mi serve il driver per PCI Device 27D8. Il mio PC funziona co l sistema operativo Windows XP Media Center Edition. Grazie.
Hi cladio,
Could you please reply with your system model to better assist you?
For us to see your system model you can attach the msinfo32 file.
Msinfo32 instructions:
  1. Please press Windows Key + R to open the Run Menu
  2. Type msinfo32 and click OK
  3. While viewing the System Summary node go to File then Save (Please do not use Export)
  4. Save your MSINFO32 report as msinfo32.nfo on your desktop for easy access and then you can post it here.
Ivan
CPozz
Buongiorno,
grazie del messaggio.
In allegato invio il msinfo32.nfo
Cordiali saluti.
Claudio
According to the motherboard model you have MS 7187 you can locate the drivers for your system from your system manufacturer website. You can try to locate them here:
http://sciencespaces.com/notebooks/medion/medion-ms-7187/23925/ http://sciencespaces.com/notebooks/medion/medion-ms-7187/23925/
I'm sorry, this is an old system and I was not able to find much information about it
Best wishes,
Ivan
CPozz
Buongiorno Ivan,
Grazie lo stesso per l'interesse dimostrato.
Cordiali saluti
Claudio
You're very welcome!
I hope the information provided above can be useful for you.
Ivan
