23808 Discussions
driver problem
KumarAdarsh
Hi, so I downloaded a game called Call of duty but whenever I open it says me to update my driver by going to manufacturers web.(intel corp.) but there it says my driver is upto date. What should i do in this problem please help.
n_scott_pearson
This is a bug in the game. The game developers implemented a driver version check that simply does not understand how the four components of a version number are used and will increment over time.
You have the correct drivers for your Intel GPU. You should not downgrade trying to overcome the affects of this bug. If the game will allow you to proceed and play, you may ignore the warning and do so. If not, then you will need to contact the game developers and demand a fix.
