23544 Discussions
driver stuck in an infinite loop
The driver igxprd32 for the display device \Device\Video0 got stuck in an infinite loop. The same problem with 6.14.10.5160
Driver_version: Ver:14.38.10.5132
Game_application: torchlight
Desktop_Screen_Resolution: 1280 x1024
Desktop Color Depth: True Color (32 bit)
Desktop_Refresh_Rate: 60 Hz
Issue: driver infinite loop
Changes:
diagnostic_report: Intel(R) Graphics Media Accelerator Driver Report
Report Date: 11/08/2009
Report Time[hr:mm:ss]: 18:38:30
Driver Version: 6.14.10.5132
Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)
Default Language: Russian
DirectX* Version: 9.0
Physical Memory: 3037 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 16 MB
Processor: x86 family 6 Model 23 Stepping 10
Processor Speed: 2806 MHZ
Vendor ID: 8086
Device ID: 2E22
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Intel(R) G45/G43 Express Chipset
Video BIOS: 1702.0
Current Graphics Mode: 1280 x 1024 True Color (60 Hz)
THREAD_STUCK_IN_DEVICE_DRIVER (ea)
The device driver is spinning in an infinite loop, most likely waiting for
hardware to become idle. This usually indicates problem with the hardware
itself or with the device driver programming the hardware incorrectly.
If the kernel debugger is connected and running when watchdog detects a
timeout condition then DbgBreakPoint() will be called instead of KeBugCheckEx()
and detailed message including bugcheck arguments will be printed to the
debugger. This way we can identify an offending thread, set breakpoints in it,
and hit go to return to the spinning code to debug it further. Because
KeBugCheckEx() is not called the .bugcheck directive will not return bugcheck
information in this case. The arguments are already printed out to the kernel
debugger. You can also retrieve them from a global variable via
"dd watchdog!g_WdBugCheckData l5" (use dq on NT64).
On MP machines it is possible to hit a timeout when the spinning thread is
interrupted by hardware interrupt and ISR or DPC routine is running at the time
of the bugcheck (this is because the timeout's work item can be delivered and
handled on the second CPU and the same time). If this is the case you will have
to look deeper at the offending thread's stack (e.g. using dds) to determine
spinning code which caused the timeout to occur.
Arguments:
Arg1: 893ba4c8, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 89699ab0, Pointer to a DEFERRED_WATCHDOG object.
Arg3: 8936c5d0, Pointer to offending driver name.
Arg4: 00000003, Number of times this error occurred. If a debugger is attached,
this error is not always fatal -- see DESCRIPTION below. On the
blue screen, this will always equal 1.
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Could not read faulting driver name
ERROR - could not read driver name for bugcheck parameter 3
Mini Kernel Dump does not contain unloaded driver list
FAULTING_THREAD: 893ba4c8
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
BUGCHECK_STR: 0xEA
LAST_CONTROL_TRANSFER: from 00000000 to bf06c816
STACK_TEXT:
8a41b1b0 00000000 00000000 00000000 00000000 igxpdv32+0xe816
STACK_COMMAND: .thread ffffffff893ba4c8 ; kb
FOLLOWUP_IP:
igxpdv32+e816
bf06c816 f6c410 test ah,0x10
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: igxpdv32+e816
MODULE_NAME: igxpdv32
IMAGE_NAME: igxpdv32.DLL
DEBUG_FLR_IMAGE_TIMESTAMP: 4aba61e4
BUCKET_ID: WRONG_SYMBOLS
1.I have the same problem ,my video chipset is g41 with driver 6.14.10.5160.
2.is there any problem with the driver 6.14.10.5160?why it have been removed from intel driver download website?
