23486 Discussions
dual monitors on HP Deskpro 400 and HD Graphics 4600?
VHamm
Hello All -
The school at which I am a technologist purchased 90 HP Deskpro 400s.
The computers contain an Intel HD Graphics 4600.
About 25 of these are slated for dual monitors and have both a VGA and a DVI-D Dual Link output.
I have connected one of the Deskpros to two monitors, both are an HP L1706 and I want to do an extended display on these two monitors.
One is connected to the VGA output and works just fine. The other is connected to the DVI via a VGA - DVI adapter.
Nothing appears on the monitor connected to the DVI at all. In fact, the power light on that monitor stays amber.
I talked to HP support and they said the arrangement I want would work.
I have done everything I can think of to solve the problem, starting with basics (restarting after physical connection, updating drivers, etc.).
I have also gone through BIOS to look for a pertinent setting and on the motherboard itself for a possible jumper or whatever.
Still no good.
Is it possible to do an extended display under these conditions?
Thanks to anyone able to help!!!
Vincent
AP16
Valued Contributor III
The DVI-D interface cannot be converted to VGA - it contains only TMDS digital signal lines. You need a PC with DVI-I ports, but such configuration is unusual for integrated graphics. In your case the only ways are:
- use second monitors with DVI ports (not yours L1706)
- install a separate graphics cards into PCs (even G210-like should be enough, just check that DVI interface on it is DVI-I, https://en.wikipedia.org/wiki/Digital_Visual_Interface# /media/File:DVI_Connector_Types.svg wikipedia to help)
