23564 Discussões
error installing graphics update code 999
cacharly
Principiante
2.213 Visualizações
Intel® 11th – 14th Gen Processor Graphics - Windows*
Installation failed with error code 999
Edition Windows 11 Pro
Version 25H2
OS build 26200.7623
Experience Windows Feature Experience Pack 1000.26100.275.0
12 Respostas
cacharly
Principiante
2.208 Visualizações
here is the ssu scan
VonM_Intel
Moderador
2.177 Visualizações
Hi cacharly,
Thank you for posting in our Community. To better assist you, could you kindly provide some additional details:
  • Have you tried performing a clean driver installation using DDU (Display Driver Uninstaller) before installing the latest driver?
  • I think the "Installation failed with error code 999" message came from the Intel Driver & Support Assistant (IDSA), is that correct? Also, could you clarify if you tried installing the driver through IDSA, or was it a manual download?
  • Could you confirm whether you have any pending Windows updates installed, as these can sometimes affect driver installations?
  • If possible, could you kindly provide a screenshot showing where this error appears?
Have a nice day!
Von M.
cacharly
Principiante
2.133 Visualizações
original reason to update is
video screen keeps disappearing   sometimes with icons  most times just the task bar and zero icons
if i sit and wait a few minutes it will catch up   like it gets stuck in cache
prior to this   i went to device manager and uninstalled display graphics driver    then rebooted  tried to install from isda again-- same
created restore point and then booted to safe mode
ran DDU in safe mode     it rebooted when it finished
ran idsa again    says to install graphics update
selected install    and i still get the same         error 999
computer has all the latest windows updates    (no updates found)
error appears in idsa       installing what is recomended     101.8425_101.8362    which is what idsa says needs updaated
I do appreciate any assistance   so Thank You
VonM_Intel
Moderador
2.122 Visualizações
Hello cacharly,
First off, thank you for walking me through everything you’ve already done. Screen disappearing, sometimes only the taskbar showing, system “catching up” after a few minutes, and IDSA throwing Error 999 during driver install, this strongly points to the graphics driver being stuck or not properly registering in Windows. Let’s reset it cleanly in a slightly different way. Follow these steps carefully:
  1. Open Device Manager.
  2. Expand Display Adapters.
  3. Right-click your Intel Graphics driver and select Update Driver.
  4. Click Browse my computer for drivers.
  5. Select Let me pick from a list of available drivers on my computer.
Now here’s the important part:
  • If you see older Intel driver versions listed, select one of the older versions and click Next.
  • If you do not see older Intel drivers, select Microsoft Basic Display Adapter (or Standard VGA Graphics Adapter, or something similar) and click Next.
Once that completes:
  1. Open Intel Driver & Support Assistant (IDSA) again.
  2. Run the graphics update installation.
  3. Reboot the system after installation finishes.
If you encounter a "write error" again:
Repeat steps 1–5 above. But this time, when you reach Let me pick from a list…, look for the latest Intel graphics driver already listed there and select it manually. Click Next, after that, IDSA should recognize the driver correctly and show everything as up to date.
Additionally, to make it easier for you, here’s our support link: Error Message: "Installation Failed" in Intel® Driver & Support Assistant (IDSA) when Installing Intel® Graphics Driver
Okay, what we’re essentially doing here is forcing Windows to release whatever is “stuck” in the driver cache. Right now, it sounds like the system thinks something is installed, but it’s not properly initialized, which explains the disappearing screen and Error 999 behavior. Take it step by step. No rush. After you try this, let me know exactly what happens, even small details matter.
Have a nice day!
Von M.
VonM_Intel
Moderador
2.072 Visualizações
Hello cacharly,
Von M.
cacharly
Principiante
2.024 Visualizações
removed display adapter  (only 2 listed)    reset to microsoft basic
ran isda   failed again
rebooted   confirmed still in basic
udated driver from list     selected intel graphics from list and installed again
had trouble cropping image
ran isda again    still shows need to update      ran install again      still fails error 999
went back into display driver and uninstalled graphics      rebooted
back into driver select from list... selected the   101.7084 from my downloaded file
runs the install and resets video    scans again automatically and still fails 999
VonM_Intel
Moderador
1.964 Visualizações
Hello cacharly,
Thank you for walking me through everything you’ve done.
Given the repeated behavior even after a clean removal and manual installation, I will need to conduct further research and review this internally to better understand why the IDSA continues to fail with Error 999. I will post an update on this thread as soon as I have more information or confirmed next steps available.
Thank you again for your patience and detailed testing.
Von M.
VonM_Intel
Moderador
1.928 Visualizações
Hello cacharly,
Thank you again for your patience. As part of my next step, kindly confirm if the issue also occurs when you manually install the graphics driver using the installer package. Once the manual installation is completed, please check again for available updates using Intel Driver & Support Assistant.
Please let me know the result so I can proceed accordingly.
Von M.
cacharly
Principiante
1.911 Visualizações
makes no difference   does the same error whether i do it manually or auto
JeanetteC_Intel
Moderador
1.903 Visualizações
Hello cacharly,
I understand that the issue continues to occur regardless of whether you perform a manual or automatic driver installation.
After reviewing your SSU log file, I've identified that your BIOS firmware is outdated. I strongly recommend reaching out to your system manufacturer's support team for assistance with updating your BIOS firmware to the latest version (GGCN61WW). An outdated BIOS can sometimes cause compatibility issues with newer graphics drivers and may be contributing to the problem you're experiencing.
After updating your BIOS, please perform a clean installation of the latest Intel driver (version 32.0.101.7084). If the issue continues, try the same clean installation process using the OEM driver (version 31.0.101.5522) instead.
Should the problem persist after trying both drivers, please generate and share a new SSU log file so we can further analyze your system configuration.
Looking forward to your next update.
JeanetteC.
VonM_Intel
Moderador
1.830 Visualizações
Hello cacharly,
Von M.
VonM_Intel
Moderador
1.391 Visualizações
Hello cacharly,
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Responder
