23729 Discussions
error installing intel driver support assistant error code 80070643
GWeir2
Hi All,
I know this has been posted before but never found a resolution there is a SSD Intel drive I'm trying to get to connect to another PC to safely backup the data off it & shows up in device manager but can't get drivers for it & this is the error message assistant has when installing...
[0468:0968][2017-10-02T11:30:56]i001: Burn v3.11.0.1701, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\ABITWI~1\AppData\Local\Temp\{F8D5A581-2E01-482F-BC8E-82984C82A36A}\.cr\Intel Driver and Support Assistant Installer.exe
[0468:0968][2017-10-02T11:30:56]i000: Initializing string variable 'LaunchTarget' to value '[ProgramFilesFolder]\Intel Driver and Support Assistant\DSAServiceHelper.exe'
[0468:0968][2017-10-02T11:30:56]i000: Initializing string variable 'LaunchArguments' to value 'installstartup'
[0468:0968][2017-10-02T11:30:56]i009: Command Line: '"-burn.clean.room=C:\Intel\Intel Driver and Support Assistant Installer.exe" -burn.filehandle.attached=180 -burn.filehandle.self=188'
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Intel\Intel Driver and Support Assistant Installer.exe'
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Intel\'
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ABITWI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20171002113056.log'
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'WixBundleName' to value 'Intel® Driver & Support Assistant'
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel'
[0468:08BC][2017-10-02T11:30:56]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[0468:08BC][2017-10-02T11:30:56]i000: Setting version variable 'WixBundleFileVersion' to value '3.0.0.9'
[0468:0968][2017-10-02T11:30:56]i100: Detect begin, 3 packages
[0468:0968][2017-10-02T11:30:56]i000: Setting string variable 'NETFRAMEWORK45' to value '394271'
[0468:0968][2017-10-02T11:30:56]i052: Condition 'NETFRAMEWORK45 >= 378389' evaluates to true.
[0468:0968][2017-10-02T11:30:56]i101: Detected package: NetFx45Web, state: Present, cached: None
[0468:0968][2017-10-02T11:30:56]i101: Detected package: IPIPInstallerX64, state: Absent, cached: None
[0468:0968][2017-10-02T11:30:56]i101: Detected package: DriverUpdateUtilityInstaller, state: Absent, cached: Complete
[0468:0968][2017-10-02T11:30:56]i199: Detect complete, result: 0x0
[0468:08BC][2017-10-02T11:30:59]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[0468:0968][2017-10-02T11:30:59]i200: Plan begin, 3 packages, action: Install
[0468:0968][2017-10-02T11:30:59]w321: Skipping dependency registration on package with no dependency providers: NetFx45Web
[0468:0968][2017-10-02T11:30:59]i052: Condition 'VersionNT64' evaluates to true.
[0468:0968][2017-10-02T11:30:59]i000: Setting string variable 'WixBundleRollbackLog_IPIPInstallerX64' to value 'C:\Users\ABITWI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20171002113056_000_IPIPInstallerX64_rollback.log'
[0468:0968][2017-10-02T11:30:59]i000: Setting string variable 'WixBundleLog_IPIPInstallerX64' to value 'C:\Users\ABITWI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20171002113056_000_IPIPInstallerX64.log'
[0468:0968][2017-10-02T11:30:59]i000: Setting string variable 'WixBundleRollbackLog_DriverUpdateUtilityInstaller' to value 'C:\Users\ABITWI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20171002113056_001_DriverUpdateUtilityInstaller_rollback.log'
[0468:0968][2017-10-02T11:30:59]i000: Setting string variable 'WixBundleLog_DriverUpdateUtilityInstaller' to value 'C:\Users\ABITWI~1\AppData\Local\Temp\Intel®_Driver_&_Support_Assistant_20171002113056_001_DriverUpdateUtilityInstaller.log'
[0468:0968][2017-10-02T11:30:59]i201: Planned package: NetFx45Web, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0468:0968][2017-10-02T11:30:59]i201: Planned package: IPIPInstallerX64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0468:0968][2017-10-02T11:30:59]i201: Planned package: DriverUpdateUtilityInstaller, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[0468:0968][2017-10-02T11:30:59]i299: Plan complete, result: 0x0
[0468:0968][2017-10-02T11:30:59]i300: Apply begin
[0468:0968][2017-10-02T11:30:59]i010: Launching elevated engine process.
[0468:0968][2017-10-02T11:31:00]i011: Launched elevated engine process.
[0468:0968][2017-10-02T11:31:00]i012: Connected to elevated engine.
[09D8:0134][2017-10-02T11:31:00]i358: Pausing automatic updates.
[09D8:0134][2017-10-02T11:31:06]w308: Automatic updates could not be paused due to error: 0x80070422. Continuing...
[09D8:0134][2017-10-02T11:31:06]i360: Creating a system restore point.
[09D8:0134][2017-10-02T11:31:06]w363: Could not create system restore point, error: 0x80070422. Continuing...
[09D8:0134][2017-10-02T11:31:06]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{01f3f6b8-1a81-4b10-b51f-f69af12e1d69}, options: 0x7, disable resume: No
[09D8:0134][2017-10-02T11:31:06]i000: Caching bundle from: 'C:\Users\ABITWI~1\AppData\Local\Temp\{F2604B24-B67B-45BD-85CF-1969483B83F5}\.be\Intel Driver and Support Assistant Installer.exe' to: 'C:\ProgramData\Package Cache\{01f3f6b8-1a81-4b10-b51f-f69af12e1d69}\Intel Driver and Support Assistant Installer.exe'
[09D8:0134][2017-10-02T11:31:06]i320: Registering bundle dependency provider: {01f3f6b8-1a81-4b10-b51f-f69af12e1d69}, version: 3.0.0.9
[09D8:0134][2017-10-02T11:31:06]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{01f3f6b8-1a81-4b10-b51f-f69af12e1d69}, resume: Active, restart initiated: No, disable resume: No
[09D8:078C][2017-10-02T11:31:06]i305: Verified acquired payload: IPIPInstallerX64 at path: C:\ProgramData\Package Cache\.unverified\IPIPInstallerX64, moving to: C:\ProgramData\Package Cache\{8FD6FE5A-E1E1-47F3-BBE6-FE2B1364DCB8}v7.1\IntelProductImprovementProgramInstaller.msi.
[09D8:078C][2017-10-02T11:31:06]i304: Verified existing payload: DriverUpdateUtilityInstaller at path: C:\ProgramData\Package Cache\{2394186A-5445-4293-B739-352009350342}v3.0.0.9\Intel Driver and Support Assistant Installer.msi.
[09D8:0134][2017-10-02T11:31:06]i323: Registering package dependency provider: {8FD6FE5A-E1E1-47F3-BBE6-FE2B1364DCB8}, version: 7.1, package: IPIPInstallerX64
[09D8:0134][2017-10-02T11:31:06]i301: Applying execute package: IPIPInstallerX64, action: Install, path: C:\ProgramData\Package Cache\{8FD6FE5A-E1E1-47F3-BBE6-FE2B1364DCB8}v7.1\IntelProductImprovementProgramInstaller.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"'
[09D8:0134][2017-10-02T11:31:27]e000: Error 0x80070643: Failed to install MSI package.
[09D8:0134][2017-10-02T11:31:27]e000: Error 0x80070643: Failed to execute MSI package.
[0468:0968][2017-10-02T11:31:27]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[0468:0968][2017-10-02T11:31:27]i319: Applied execute package: IPIPInstallerX64, result: 0x80070643, restart: None
[0468:0968][2017-10-02T11:31:27]e000: Error 0x80070643: Failed to execute MSI package.
[09D8:0134][2017-10-02T11:31:27]i318: Skipped rollback of package: IPI...
Hi gruntly69,
We understand your situation regarding the Intel® Driver & Support Assistant that you are not able to install due to error code 80070643.
We would like to let you know that this application only supports the following products: Graphics drivers, wireless networking, Intel® NUCs, and Intel® Compute Sticks. We already tested the application in our lab and it does not provide SSDs information or drivers.
https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant?product=128824 Intel® Driver & Support Assistant - downloadcenter.intel.com
This SSD does not require any driver to work since it is a SATA SSD.
We would like to confirm the following information:
-Please post a screenshot of the device manager with the "Disk drives" tab expanded.
-Under device manager, Right click the unknown device and select properties.
-Go to the "Details" Tab.
-Under the drop-down menu, select the option that says "Hardware ID".
-Please provide us the information that is available there.
-Repeat the same process with the "Mass Storage Controller" that is listed under other devices too.
We look forward to hearing back from you.
Junior M.
Hi gruntly69,
We haven't heard back from you in a while. We would like to know if there is something else we can assist you with.
Junior M.
