23106 Discussions
glVertexArrayAttribIFormat not working correctly on Intel HD Graphics 530
Vadim54
Hello Intel Community,
I'm encountering an issue with glVertexArrayAttribIFormat on my Intel HD Graphics 530 GPU.
System details:
  • GPU: Intel(R) HD Graphics 530
  • Driver version: 31.0.101.2111
  • OpenGL version: 4.6.0 - Build 31.0.101.2111
  • GLSL version: 4.60 - Build 31.0.101.2111
  • OS: Windows 10 64-bit
Problem:
I'm using the following input in my vertex shader:
layout (location = 5) in uint inst_inTransformIndex;
And the corresponding VAO setup in code is done using glVertexArrayAttribIFormat:
glVertexArrayAttribBinding(vao, 5, 1);
glVertexArrayAttribIFormat(vao, 5, 1, GL_UNSIGNED_INT, 24);
glEnableVertexArrayAttrib(vao, 5);
The buffer contains valid uint32_t data, and the attribute is correctly bound with divisor 1 via:
glVertexArrayVertexBuffer(vao, 1, instanceBuffer, 0, stride);
glVertexArrayBindingDivisor(vao, 1, 1);
However, the attribute value seen in the shader is either 0 or garbage.
If I instead switch the shader input to:
layout (location = 5) in float inst_inTransformIndex;
...and use glVertexArrayAttribFormat with the same data, the values work correctly.
Even more interestingly:
  • On a system with an NVIDIA RTX 3060 Laptop GPU, using the same code, everything works perfectly — including with uint and glVertexArrayAttribIFormat.
  • If I attach RenderDoc to the application, the issue disappears — the data is passed correctly, even on Intel HD Graphics 530.
Full OpenGL VAO setup (captured from RenderDoc):
glCreateVertexArrays(1, VertexArray_FilledRectangles);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 0);
glVertexArrayAttribFormat(VertexArray_FilledRectangles, 0, 2, GL_FLOAT, GL_FALSE, 0);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 0, 0);
glVertexArrayVertexBuffer(VertexArray_FilledRectangles, 0, GeometryBuffer_FilledRectangles, 0, stride);
glVertexArrayBindingDivisor(VertexArray_FilledRectangles, 0, 0);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 1);
glVertexArrayAttribFormat(VertexArray_FilledRectangles, 1, 2, GL_FLOAT, GL_FALSE, 0);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 1, 1);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 2);
glVertexArrayAttribFormat(VertexArray_FilledRectangles, 2, 1, GL_FLOAT, GL_FALSE, 8);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 2, 1);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 3);
glVertexArrayAttribFormat(VertexArray_FilledRectangles, 3, 2, GL_FLOAT, GL_FALSE, 12);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 3, 1);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 4);
glVertexArrayAttribFormat(VertexArray_FilledRectangles, 4, 4, GL_UNSIGNED_BYTE, GL_TRUE, 20);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 4, 1);
glEnableVertexArrayAttrib(VertexArray_FilledRectangles, 5);
glVertexArrayAttribIFormat(VertexArray_FilledRectangles, 5, 1, GL_UNSIGNED_INT, 24);
glVertexArrayAttribBinding(VertexArray_FilledRectangles, 5, 1);
glVertexArrayVertexBuffer(VertexArray_FilledRectangles, 1, InstancesBuffer_FilledRectangles, 0, stride);
glVertexArrayBindingDivisor(VertexArray_FilledRectangles, 1, 1);
glVertexArrayElementBuffer(VertexArray_FilledRectangles, IndexBuffer_FilledRectangles);
glObjectLabel(GL_VERTEX_ARRAY, VertexArray_FilledRectangles, -1, "VertexArray_FilledRectangles");
Question:
Is there a known issue or limitation with glVertexArrayAttribIFormat on Intel HD Graphics 530 with this driver version? Is there a recommended workaround, or would using float instead of uint be the only reliable alternative?
Thanks in advance for any help or insight!
Felix-CodingClimber
I have exactly the same issue.
After I changed the attribute from uint to float it works.
My System Specs:
  • GPU: Intel(R) Iris(R) Xe Graphics
  • Driver version: 32.0.101.6556
  • OpenGL version: 4.6.0 - Build 32.0.101.6556
  • GLSL version: 4.60 - Build 32.0.101.6556
  • OS: Windows 11 64-bit
