23671 Discussions
graphic card
yuvraj_shekhawat
I have an intel i5 11 gen with iris xe graphic card, so I'm facing issues regarding fps in GTA 5,even at the lowest resolution I'm getting fps below 20
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
DesomZues
I was also suffering from the same issue, but Thankyou for your guidance, I will let you ask again if I need any favor from you.
But I think It will be enough for me because I read it and I'm **bleep** sure My issue will be fixed soon.
