23717 Discussions
grey screen after sleep
MPage
I have an Intel Core i5-7500 CPU 3.40 Ghz in a newly built PC.
Every time I wake it from sleep I get a grey screen with vertical lines and a small box that moves around the screen with the mouse -see attached picture. There is no way to recover the session and I have to reboot the PC by holding the power button.
I suspect that the problem is with the display driver which is an HD Graphics 630 22.20.16.4815. As it is a new build, I cannot roll back to an earlier version.
Any suggestions?
Stefan3D
Actually there are older drivers you can try: https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 Downloads for Intel® HD Graphics 630
Stefan3D
MPage
Thanks for the link.
I have installed the earliest available driver and it has fixed the problem.
I have disabled the Intel automatic update, just need to work out how to stop microsoft from updating it.
MPage
I have downloaded the troubleshooter but none of the drivers listed matches the driver that I have just installed.
ssote
New Contributor II
I have the same problem as the OP after Creators update 1709 and loading different drivers did not fix the problem, now the change is rare random when vertical lines and a small box happens with the original drivers.
n_scott_pearson
Anther thing to check - Some BIOSs have a configuration parameter that allows you to indicate that you want the graphics interface to be fully re-initialized by the BIOS before returning control to the O/S. If your's has this capability, try enabling it and see if it helps.
