23851 Discussions
hdcp 1.4 needed
ArnoldS9
I have an Intel i5-9600k cpu installed on an Asus  Prime Z390-A motherboard. The graphics is Intel UHD Graphics 630. To use some devices I need hdcp 1.4. How can I enable or install hdcp 1.4?
n_scott_pearson
Intel's processors contain support for HDCP 2.2 or better. HDCP 2.x is NOT backwards compatible with HDCP 1.x. There is no way to get HDCP 1.4 support. Hopefully HDCP 2.2 will suffice; if not, AFAIK, you are out of luck.
