hello,
doesn't matter how hard i tried, i can't make the computer to shown on TV with hdmi cable.
this laptop has intel hd graphics card.
core I5.
important notes:
i saw that the computer identify my hair TV (it added to list of displays with correct name (hair TV)).
when i start extended mode i can move the mouse or windows out of laptop screen (as if there is a second screen).
but i can't see any image in the tv.
what i did so far:
i go to hp site and downloaded every display and audio driver.
i search in the forums and all said its driver problem.
i check the same cable in same TV with other computer and it worked great so the TV and cable ok.
trying with other cables on same tv.
trying in a lot of tv's
(when i try with computer screen that has hdmi port it worked)
all the other computer worked with any tv and any cable.
i tried everything, extended display, duplicate display, just projector and nothing seem to work.
trying to update driver.
trying to install new drivers from hp site.
trying to install last driver from intel site.
trying to insall older drivers from intel site.
trying to update chipset drivers.
trying to update bios drivers (still can't see there any setting about hdmi).
trying to play with the refresh rates 29/30/59/60 Hz and screen resolution (tv and laptop displays).
trying to run win xp from hiren's boot cd.
thought of possible problems:
maybe it's have a connection with pal/ntsc problem?
(the computer is from US where using ntsc and the tv is from israel like europe using PAL.)
but as i know pal/ntsc is just from analog signals not for hdmi.
maybe it's somehow about refresh rates 50/60 Hz.
maybe it's about digital/analog hdmi protocls.
maybe it's about HDCP.
additional info:
I'm a programmer and computer repair technician so i know what i do.
but nothing.
I'm running win7 home premium.
please help me.
i must solve this.
if i can't solve it, it means i need to sell my computer and it's new computer.
and i add extra 200$ for warranty.
thx a lot.
- Tags:
- HDMI
Hi there!
I am not quite sure if you have tried different TV on same laptop computer. If you did, please try pasting the graphics report generated within graphics properties.
See below to pull graphics diagnostics report
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Allan.
hello,
i tried with a lot of tv's.
it only worked with computer screen with hdmi.
thx for your help!
im totaly lost.
this is the report:
Intel® HD Graphics (Core i5) Report Date: 5/24/2011Report Time[hr:mm:ss]: 20:59:49Driver Version: 8.15.10.2361Operating System: Windows 7 Service Pack 1(6.1.7601)Default Language: Hebrew (Israel)DirectX* Version: 10.1Physical Memory: 3893 MBMinimum Graphics Memory: 32 MBMaximum Graphics Memory: 1696 MBGraphics Memory in Use: 71 MBProcessor: Intel64 Family 6 Model 37 Stepping 5Processor Speed: 2527 MHzVendor ID: 8086Device ID: 0046Device Revision: 02 * Accelerator Information * Accelerator in Use: Intel(R) HD GraphicsVideo BIOS: 2050.0Current Graphics Mode: 1366 by 768 * Devices Connected to the Graphics Accelerator * Active Notebook Displays: 1* Built-in Display * Monitor Name: Generic PnP MonitorDisplay Type: DigitalGamma Value: 2.2DDC2 Protocol: Supported Maximum Image Size:Horizontal: 13.39 inchesVertical: 07.48 inches Monitor Supported Modes:1366 by 768 (60 Hz) Display Power Management Support:Standby Mode: Not SupportedSuspend Mode: Not SupportedActive Off Mode: Not Supported Raw EDID:00 FF FF FF FF FF FF 00 30 E4 AC 02 00 00 00 0000 14 01 03 80 22 13 78 0A C1 25 9D 5F 5B 9B 2719 50 54 00 00 00 01 01 01 01 01 01 01 01 01 0101 01 01 01 01 01 12 1B 56 78 50 00 0E 30 20 2024 00 58 C2 10 00 00 19 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE00 4C 50 31 35 36 57 48 32 2D 54 4C 51 42 00 C1 * Other names and brands are the property of their respective owners. *- Mark as New
just want to say gilad shoham is me (i wrote the above message, just forgot to login before)
Had any luck yet?? I'm pulling my hair out trying to solve a similar problem. All drivers are updated but still no detection on TV.
