23525 Discussions
how to disable vsync on intel uhd 620?
leo15
I want to disable the vsync function but I don't know how, I've looked in different places and I haven't found anything about it
Andres_Intel
Hello leo15,
Thank you for posting on the Intel®️ communities. I see you want to know how to disable vsync for your Intel® UHD Graphics 620, I will be happy to help you.
I will start with an investigation of this request to provide you with the correct steps, I will provide you with the information as soon as possible.
Andres P.
Andres_Intel
Hello leo15,
I have been working on the investigation and you can use Intel® Arc Control for disabling vsync. Before installing it remember to check the minimum requirements on How to Install Intel® Arc Control.
In case your system does not meet the minimum requirements you can use as a workaround Intel® Graphics Command Center (Beta). For guidance, Enabling and Disabling Vertical Synchronization.
Just for you to know we use to have this feature available on the Intel® Graphics Command Center (IGCC), but gaming related features have been moved to our newest gamer-focused user interface, Intel® Arc™ Control.
If these two options do not work, the last one is to check if the game or app has the feature to be set it off.
Andres P.
Andres_Intel
Hello leo15,
Andres P.
Andres_Intel
Hello leo15,
Andres P.
