23091 Discussions
how to fix windows 10 has blocked application from accessing graphics card
jpeak
so things worked fine before i went to windows 10, now when i launch fallout 4, total war rome 2, or total war shogun 2 i get 'application has been blocked from accessing graphics card'. befre i get this error i had one where graphics would crash than recover, which i fixed by going into reg edit and changing some values. From what i can tell is the only fix is to wait for new graphics driver or upgrade you hardware (which is expensive) and i see a lot of other people having this problem too yet i cant find a fix that works. how do i fix this
Hello Sashalaska,
In order to get more information and provide to you the correct drivers, please try the "dxdiag" Windows® command, by performing the following steps; please attach the results in a comment.
Steps:
  • Windows key + "R"
  • Type dxdiag
  • Hit save all information button
  • Attach the .txt file to your answer
Hellen.
jpeak
All seems to be fine, I suggest you to wait for a new version of drivers, because you have last Driver version; you can also verify if there is a new version in your OEM drivers, in the link below.
http://www.dell.com/support/home/us/en/19/Products/?app=drivers http://www.dell.com/support/home/us/en/19/Products/?app=drivers
Hellen.
