22940 Discussions
i3 HD Graphics and pixel shader 3.0?
I'm trying to play a game called Magicka.
They say it doesn't support integrated graphics.
When I asked if a laptop with integrated graphics could ever run the game,
someone said:
"Magicka is using pixelshader 3.0, which means that it depends on running programs on the GPU that your hardware simply can't support.
Except for a rewrite of the rendering engine, I can pretty certainly say that the answer is no."
So is this accurate? Does my i3-m350's integrated graphics not have pixel shader 3.0?
Could I use this as a work around? http://transgaming.com/business/swiftshader/ http://transgaming.com/business/swiftshader/
Do I have any hope of playing this game?
Bless you!
Allan_J_Intel1
Actually, the Intel HD Graphics supports shader model 4.0, this is enabled after you install the latest graphics driver.
Try this link to get the latest:
http://www.intel.com/support/graphics/detect.htm http://www.intel.com/support/graphics/detect.htm
Intel has released a list of tested games for your graphics controller. If your game is not on the list, I am afraid has not been tested.
http://www.intel.com/support/graphics/sb/cs-012643.htm?wapkw=(game+compatibility http://www.intel.com/support/graphics/sb/cs-012643.htm?wapkw=(game+compatibility)
Allan.
DLaur3
Hello i have a laptop HP 630 with this specs:
Procesor:Intel(R)Core(TM) i3 CPU M380 @ 2.53DHz
Installed memory(RAM) 4.00 GB
System tipe: 64-bit Operating System
Windows 7 Proffesional ,Service Pack 1
Intel HD Graphics (core i3) Driver version 8.15.10.2202 , Direct X Version 10.0
Video BIOS :2111.0
I don t know what version is on my notebook because of this I detailed all the components on it ,probably is intel hd graphics 2000 or 3000, please tell me if it supports pixel shader 3 this model or if they are new drivers to improve the performance for this model.I want to know what games can I play with this laptop and if it is a list made for my model processor.I want to know if I can play Counter Strike Global Offensive, Call of Duty: Modern Warfare 2 and 3, Battlefield: Bad Company, Street Fighter IV and others.
Waiting for reply as soon as possible, thank you!
Allan_J_Intel1
I understand you are looking for game compatibility and shader model support.
Based on the processor specifications, the graphics controller on your system is first generation Intel HD Graphics; this is not HD 2000 or 3000.
The Intel HD Graphics supports shader model 4.0, this is enabled after you install the latest graphics driver.
The link below provides a list of playable games for your graphics controller:
http://www.intel.com/support/graphics/sb/CS-031017.htm http://www.intel.com/support/graphics/sb/CS-031017.htm
Please bear in mind games such Battlefield, Street Fighter 4, Call of Duty, etc, were designed to specifically to take advantage of high-end graphics.
If you are looking for an updated video driver, try this link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
Allan.
MMISS24
I have downloaded the latest drivers for intel hd graphics i3 version 8.15.10.2993 but shaders 3.0 aren't still supported. I checked it by GPU caps viewer and it shows that supported just 2.0 not over
Allan_J_Intel1
glclal, I am sorry about the trouble, I have confirmed through engineering that once you install the latest video drivers, shader model is available with version 4, please take a look at some specifications here:
http://www.intel.com/support/graphics/sb/CS-033757.htm http://www.intel.com/support/graphics/sb/CS-033757.htm
Allan.
Olá boa tarde! Alguém poderia me ajudar? Estava fuçando os programas pelo painel de controle do note para desinstalar algum programa que possívelmente estivesse muito pesado e acabei desinstalando o gpu shader 3.0. Agora meu jogo Pes 2012 não roda mais. Como posso reinstalar este programa?
