23263 Discussions
i5 3450 no se actualiza
FJure
i5 3450 no se actualiza a la version mas reciente que es la 15.33.43.4425 y esta en la 10.18.10.4425 y no puedo jugar a need for speed 2016
Hello Metaldragon,
The last four digits of the driver version will indicate the version you have installed. In your case .4425 is the version, the rest of digits will indicate the driver baseline and the revision, this link gives a detailed explanation; http://www.intel.my/content/www/my/en/support/graphics-drivers/000005654.html Understanding the Intel® Graphics Driver Version Number.
The minimum requirements to play this game can be found here; http://www.systemrequirementslab.com/cyri/requirements/need-for-speed-2016/13109 Need For Speed (2016) system requirements | Can I Run Need For Speed (2016). Note that the recommended processor is a 4th generation processor.
Amy.
FJure
yo tengo el mismo problema que esta persona, ya prove descargarlo de la web y me pasa lo mismo
Metaldragon, thank you for sharing that link.
Please refer my previous input, there you can check that the game requires 4th generation processor in order to perform properly. The game will not likely run if the minimum requirements are not meet, bear in mind that you have a 3rd generation processor so it is unlikely that the game will run in your system.
Amy.
