23069 討論
i7-3770 integraded graphics driver issue
ROlso
初學者
6,425 檢視
I'm having trouble installing the driver Intel HD 4000 for I7-3770. I tried the Intel Update System but it did not detect the graphics. I tried manually updating by downloading a standalone but whenever I install it, it is not compatible/cpu not support.
Need help
0 積分
6 回應
Stefan3D
榮譽貢獻者 II
4,535 檢視
I guess the update utility fails because your processor has reached EOL
https://ark.intel.com/products/65719/Intel-Core-i7-3770-Processor-8M-Cache-up-to-3_90-GHz Intel® Core™ i7-3770 Processor (8M Cache, up to 3.90 GHz) Product Specifications
Here are all compatible drivers:
https://downloadcenter.intel.com/product/65719/Intel-Core-i7-3770-Processor-8M-Cache-up-to-3-90-GHz- Downloads for Intel® Core™ i7-3770 Processor (8M Cache, up to 3.90 GHz)
ROlso
初學者
4,535 檢視
I've already tried all the compatible drivers.
Stefan3D
榮譽貢獻者 II
4,535 檢視
ROlso
初學者
4,535 檢視
Tried that one
員工
4,535 檢視
Hello Raft890,
I understand you are having troubles installing our Intel graphics driver.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
May I have the exact error message you are getting during driver installation?
What is the issue you are having in the computer that is making you update graphics driver?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
員工
4,535 檢視
Hello Raft890,
I was wondering if you still need assistance regarding the graphics driver you are trying to install. In case you still need assistance just let me know.
Fred D.
回覆
