23526 Discussions
[i7-8700K] XMP messes with Intel Display Audio?
MMoha18
So I recently purchased a i7 8700K and am running it on an Asus Strix Z370-F (latest BIOS 0430).
I have this issue where if I enable the default XMP for my G.Skill 32 GB DDR4 8X4 3200 MHz RAM,
I end up having choppy and bit crushed audio on my Predator XB271HU via the HDMI port. If I disable XMP, it seems to fix the issue.
Already ran memory tests from my BIOS and it found no issues.
Updated to the latest Nov 17 drivers, no change.
Latest Windows 10.
So to recap,
- 8700K with stock XMP
- no OC or other changes
= choppy audio performance, almost unusable.
Even my video freezes along with audio.
But nothing a restart cant fix.
My temps are fine btw, have a Kraken x62.
Any one else with similar issues?
mohitm: Thank you very much for contacting the Intel® communities. We are sorry to hear there is an audio problem.
In order to try to fix this problem we recommend to install the graphics driver provided by ASUS, look for VGA version 4758:
https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-F-GAMING/HelpDesk_Download/ https://www.asus.com/us/Motherboards/ROG-STRIX-Z370-F-GAMING/HelpDesk_Download/
If the problem persists we can try to install driver version 4849:
https://downloadcenter.intel.com/download/27266/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?product=126790 https://downloadcenter.intel.com/download/27266/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?product=126790
Just to rule out a possible problem with one of the memory sticks, with the XMP profile enabled, could you please test the PC with just one stick of RAM with each RAM stick?
Any further questions, please let me know.
Alberto R
MMoha18
Hi Alberto,
Thanks for the response.
Did that.
https://downloadcenter.intel.com/download/27266/Graphics-Intel-Graphics-Driver-for-Windows-15-60-%3Fproduct%3D126790 https://downloadcenter.intel.com/download/27266/Graphics-Intel-Graphics-Driver-for-Windows-15-60-?product=126790
Had this before I installed the aforementioned driver. As I mentioned in my previous post, I had the latest Nov 2017 Drivers.
Did that too. No Dice .
Also stress tested each RAM a bit(both 8 each and 32GB scenario) before playing audio.
The issue is the same.
With XMP -Glitchy/Crushed Audio
Without XMP - Good Audio.
Here are videos so that you can see what I'm talking about.
As you can observe after audio starts glitching, video stops too after page refresh.
It's not an issue with my internet, i've verified that.
With XMP 32 GB:
With XMP 8 GB:
Without XMP:
Do you guys think it's an issue with my silicon?
Do I need to RMA it? Or do you think it's mother board related?
I'm ready to perform more tests if that'll help you zero in on the issue.
Hi mohitm: Thank you very much for providing that information and the videos. At this point it is hard to tell for sure if the problem is the processor or the board, it could be either.
We will do further research on this matter, in order for us to be able to do that, please provide the information requested on the link below:
/message/319025# 319025 https://communities.intel.com/message/319025
Alberto R
MMoha18
Hi Alberto,
I don't see how some items in that list help as I have an Audio Issue.
Anyway find the required files attached along with the requisite form.
Description
Provide a detailed description of the issue
With default XMP enabled on an i7 8700K Asus Z700-F Strix on 0430 BIOS, audio fails consistently - sounds distorted or stops. Video stops working soon after. (tested on youtube, video describing the problem provided)
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Custom Built
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
Acer Predator XB271HU
How much memory [RAM] in the system (see note2 below).
<td style="padding: 0 5.4pt; border-top: none; border-right: 1pt solid windowtext; border-bottom: 1pt solid windowtext; border-left: none; font-style: inherit;" width...
Hi mohitm: Thank you very much for providing those files. As soon as I get any updates I will post all the details on this thread.
Alberto R
mohitm: I just received an update on this matter and actually at this point the problem does not seem to be related to the graphics driver.
In this case, we suggest to contact ASUS for further diagnostics since enabling XMP still drives the CPU MCH beyond recommended specifications:
https://www.asus.com/us/support/ https://www.asus.com/us/support/
Alberto R
