23854 Discussions
igfx stops responding
hi my problem is whenever im watching justin.tv and try to do something else the screen goes black and then says igfx has stopped responding but restarted. i just recently got the latest drivers for the mobile series 4 chipset. here are my specs if anyone can help.
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 05/16/2009
Report Time[hr:mm:ss]: 15:35:55
Driver Version: 7.15.10.1688
Operating System: Windows Vista (TM) Home Premium* , Service Pack 1 (6.0.6001)
Default Language: English
DirectX* Version: 10.0
Physical Memory: 1977 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 797 MB
Graphics Memory in Use: 85 MB
Processor: x86 family 6 Model 15 Stepping 13
Processor Speed: 2161 MHZ
Vendor ID: 8086
Device ID: 2A42
Device Revision: 07
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 4 Series Express Chipset Family
Video BIOS: 1659.0
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Notebook *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
I would suggest reverting to the previous video card driver and it will fix your problem. The new driver is what is causing the problem. I had the same problem for two days 5/14/09 and 5/15/09 till I found out that it was the driver.
thanks the igfx problem is fixed but now i notice my laptop locking up after use. i think it might have to do with the video card overheating the system but im not sure. any help on that situation would be helpful too.
