23069 Discussions
im playing csgo oin windows 8.1 pro with intel hd 2000 graphics but i cant work out how to get 4:3 black bars. can anyone help?
jlord2
im playing csgo oin windows 8.1 pro with intel hd 2000 graphics but i cant work out how to get 4:3 black bars. can anyone help? my graphics card died so have been forced to play with on board graphics, is there a way i can get 4:3 black bars in csgo
Hello, jacklord1993.
Thank you very much for contacting the Intel® Communities Team.
I understand you would like to play CS:GO™ at 4:3. I will be more than glad to assist you with this problem you are facing.
In order to achieve so, please follow these steps:
  1. In CS:GO™ interface go to Options > Video Settings
  2. Change the Aspect Ratio to Normal 4:3
  3. Change the Resolution to the highest one that the game allows you to.
  4. Then, go to your desktop, right click on it, select the Graphics Properties.
  5. In the Intel® HD Graphics properties go to Display and, change the Resolution to the resolution set on CS:GO. In addition, make sure that on the Scaling section the "Scale Full Screen" is set, if not, please select it.
  6. Restart game and computer if needed.
Please let me know the results.
Antony S.
jlord2
I only have 1 scaling option and that is maintain image scaling. I need to be able to switch to maintain aspect ratio. Is there an app I can download or is it possible to update the graphics panel interface?
jlord2
sorry, the only scaling option i have is "maintain display scaling"
Thank you very much for your prompt reply.
You can indeed perform an update for the Graphics Drivers, in order to achieve so, please download the .zip file of your Intel® HD Graphics version that better fit for your OS in our https://downloadcenter.intel.com/product/81502/Intel-HD-Graphics-2000 Download Center. Then, in order to complete the installation, follow this link: https://www.intel.com/content/www/us/en/support/articles/000005629.html https://www.intel.com/content/www/us/en/support/articles/000005629.html
Antony S.
I would like to double check if you were able to perform the troubleshooting steps that I attached in the post above and the results.
Antony S.
