23831 Discussions
intel graphic control panel gone after Intel® Driver & Support Assistant upgrade?
OAli3
intel graphic control panel gone after Intel® Driver & Support Assistant upgrade, gone from windows tray and windows desktop context menu,
before the upgrade it was in tray and desktop context menu.
VARADHARAJAN
Valued Contributor II
try to get access from installed intel graphics folder .
if you cant found out , then try resinstall latest graphics driver
OAli3
I uninstalled the latest driver, let windows update install the driver, its't latest but worked
with the way supposed to be, got back intel control panel,
I learned lesson never use intel driver support assistant utility,
only trust microsoft.
VARADHARAJAN
Good , you solved yourself , but check the intel graphics driver version , I knew windows installed old graphics version its called legacy driver .
will you share driver version , just installed
OAli3
driver installed version is 25.20.100.6323, legacy driver.
OAli3
its'n latest driver but at least installed correctly,
what benefit I will have if I installed latest driver and the installer file has bugs?
then control panel gone away,
I am very satisfied with the one I have it now,
my advice to everyone don't use intel driver support assistant utility.
OAli3
This issue is addressed only to intel support people , If you are not intel support person,
please don't reply,
DCH 25.20.100.6471 driver doesn't install software "control panel", installs only driver,
this is dangerous bug, I uninstalled this driver and installed legacy driver instead .
