23793 Discussions
intel graphics media accelerator
Hi
I am responsible for creating images for the company where i work. We have to deploy win7 32 bits to a bunch of Dell Latitude E6510 that come with a Q57 chipset and integrated Intel graphic card.
I have downloaded the driver pack from Dell website and i have a few issues with drivers installation.
Basically i know that there is a specific order to install devices according to Dell http://support.dell.com/support/topics/global.aspx/support/downloads/en/driver_install_order http://support.dell.com/support/topics/global.aspx/support/downloads/en/driver_install_order
however with the method i use i dont have control over this, i create a .wim image file and i then inject all the drivers using a tool called dsim from Microsoft.
When the laptop boots for the first time there is an error message saying that igfxdev.dll is not a valid win32 application, i believe this is the intel graphics media accelerator application dll (i have downloaded the 32 bits version and the error seems to indicate that it is trying to run the 64 bits version).
Anywhere from Intel i can dowload the 32 bits version?
The video driver works fine it is just the tray application that doesnt run.
If you are using the cpu integrated gfx, have you tried this driver?
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3145&DwnldID=19099&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3145&DwnldID=19099&lang=eng
Download and extract the files using winrar.
All the best,
Kind Regards,
Aryan
I have tried with the drivers in the link you provided but i still receive the same error message. It looks like only the Intel application fails to install (drivers are OK) after sysprep has ran.
Could it be missing dependencies?
After removin the old drivers and injecting the ones in your post it is now working fine.
Thanks a lot.
