23481 Discussions
intel graphics not working after windows 10 upgrade
NHass4
Hi..
I am using Dell inspiron N4050 laptop. Recently i have upgraded my OS from Windows 7 to Windows 10. After the upgrade i was unable to get screen resolution for 1399x768.
the driver display installed shows Microsoft Basic Display Adapter. i tried to install Intel(R) HD Graphics 3000 which was the display before the upgrade. but after install still device manager shows Microsoft Basic Display Adapter. I run the windows update and through windows update, the driver shows successfully installed but still device manager shows Microsoft Basic Display Adapter installed. I cant get the resolution for 1366x768.
please someone help me..
below is the system details and driver details from Dxdiag.
Time of this report: 8/2/2015, 20:54:37
Machine name: SOFTWARE-UPDATE
Operating System: Windows 10 Pro 32-bit (10.0, Build 10240) (10240.th1_st1.150717-1719)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N4050
BIOS: BIOS Date: 03/23/12 14:05:23 Ver: 04.06.04
Processor: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3494MB RAM
Page File: 2732MB used, 4344MB available
Windows Dir: C:\WINDOWS
DirectX Version: 11.2
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: UnKnown
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Microsoft Basic Display Adapter
Manufacturer: Intel Corporation
Chip type:
DAC type:
Device Type: Display-Only Device
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_05021028&REV_09
Display Memory: 1746 MB
Dedicated Memory: 0 MB
Shared Memory: 1746 MB
Current Mode: 1024 x 768 (32 bit) (64Hz)
Monitor Name: Generic Non-PnP Monitor
Monitor Model: unknown
Monitor Id:
Native Mode: unknown
Output Type: Internal
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: 11.2
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a.
please someone help....
NHass4
Can someone help please
JKent
I had the same problem with Intel HD 4600.
1) Intel just came out with updated drivers (in the last couple of days). Supposed to be compatible with Windows 10.
2) Are you using a docking station? I fixed my resolution problem by undocking, connecting directly to an external monitor, updating my driver, rebooting. After replacing the laptop in the docking station I had to reboot once again to get the docking station firmware to recognize the new driver and settings.
I'm responding to you on a monitor with a resolution of 1920x1080. It only took four days.
JK
NHass4
i am not using any docking station...:(
JTabl
Apparently, Intel released a production driver just before the W10 release. Though it only supports select processors. The problem is, those using intel hd graphics 2000/3000 are still left with the beta (which in my case, I still cannot install it). Anyone who knows any workaround here? Or anyone who can upload this beta driver?
Allan_J_Intel1
I have been checking the list for supported operating systems on Intel® HD Graphics 3000 and windows 10 does not appear to be supported.
See here: http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems
In other words, Intel will not release compatible drivers for windows 10 with an Intel® HD Graphics 3000.
Allan.
JTabl
"Will not", or just still hasn't? =(((
Allan_J_Intel1
There is no support for Windows 10 under Intel® HD Graphics 3000 as stated on the URL I pasted on post # 7.
Allan.
NHass4
so what can i do? i cannot watch vedio ans cannot view web pages..can u recomend a solution for this..at least recomend a driver for that i can use
Allan_J_Intel1
You need to go back to a supported operating system. You probably need to reinstall windows 7 or Windows 8. I cannot recommend drivers for your current operating system because Intel does not have compatible drivers for it.
Allan.
NHass4
NHass4
thank you Allen..do u think that they will come up with a supported driver in near future?
MSAS
Hi Friends... i have 2 win in my inspiron... win7 64,win10 64 +Remix OS
Naval... you can install win10 and update all your laptop drivers with driverpack solution
(except : amd 7400! you need to install manual)
this laptop can working better than win 7 ! hhmmm.... after update with driver pack if you any problem with drivers(maybe usb host controller) you can update your drivers with IObit driver booster
and...................... dont update alps touchpad with driver booster
download link for drp solution:
http://getintopc.com/softwares/drivers-softwares/driverpack-solution-17-4-5-final-2016-iso-free-download/ DriverPack Solution 17.4.5 Final 2016 ISO Free Download
http://dl2.soft98.ir/driver/DriverPack.Solution.17.7.4.html DriverPack Solution 17.7.4 Final :>>> this is iranian website
download once and go to win 10 without any problem
JTabl
Same problem After upgrading to Windows 10, the first thing I noticed after the first boot was that my resolution was somewhat cranked up. I checked the Display Settings and I found out that I'm only limited to 1024x768 resolution (as opposed to the original 1366x768). I checked my Display Adapter, and there I found out that my driver was replaced by Microsoft Basic Display Adapter. I tried updating through Windows Update (as there was an update to Intel HD Graphics somehow), but everytime I do the update, my pc just reboots onto the Boot logo, then restarts. I also tried booting into safe mode, installing the update manually through the C:\Windows\SoftwareDistribution\Download\Install, and the installation operation completes. The driver in place in the device manager is now the Intel HD Graphics. The thing about that is, I cannot boot into the system anymore. After the boot logo, it will then restart and so I'm stuck with reverting back to Microsoft Display Basic Adapter so I can use my laptop. I tried searching for the driver, but the intel site
https://downloadcenter.intel.com/download/25027/Intel-Iris-Iris-Pro-and-HD-Graphics-Beta-Driver-for-Windows-10 https://downloadcenter.intel.com/download/25027/Intel-Iris-Iris-Pro-and-HD-Graphics-Beta-Driver-for-Windows-10 says it's only available through Windows Update. I don't know what to do anymore, I've been dealing with this for days. Help? =((
JTabl
Another thing, I also tried uninstalling the display driver during safe mode (as everytime I do something about it during normal boot, my laptop reboots automatically), tried rebooting, tried checking Windows Update, and the I found that I don't have the update for the graphics in WinUp. And now I really don't know what to do.
asaga2
liunx is your friends
Allan_J_Intel1
All:
This information is intended to all Windows 10 users that are experiencing issues with a supported Intel® Graphics Controller (http://www.intel.com/support/graphics/sb/CS-034343.htm supported graphics)
/message/321854# 321854 Re: -NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
See post # 93
Allan.
I had the same problem with Intel HD 4600.I fixed my resolution problem by undocking, connecting directly to an external monitor, updating my driver, rebooting. After replacing the laptop in the docking station I had to reboot once again to get the docking station firmware to recognize the new driver and settings.
http://qwikfix.co.uk/hmrc-contact-number/ HMRC
Allan_J_Intel1
Thank you for your feedback. I am sure this will help others on this community.
Allan.
VGuan
Hi Naval. As co-user of Dell N4050 laptop how it it now? Is it already in W10? I had the same problem too.
some people might have already solved this.
http://www.tenforums.com/general-discussion/10374-black-screen-when-booting-my-laptop-after-upgrading-windows-10-a.html Windows 10 Forums
