23525 Discussions
is it possible to increase the dedicated memroy on iris 6100?
Hosma1
i hope there is away to do it as it has only 128mb dedicated
gbhj
there are instructions here
Hosma1
hi zeqzy, thanks for helping me,is what i did right or something is missing as i want to set the dedicated rams to 4gb , thanks
MSchm21
Valued Contributor I
Which game or application doesn't detect your shared memory properly?
Hosma1
fallout 4, games specs says it needs a 2gb video card, mine as far as i know is 8gb, after speaking with the game developers , they said that my dedicated memory is only 128mb ( which i honestly find that not honest as it should be mentioned on the game specs ) any way, i am trying to overcome this issue , by making my dedicated memory up to 4gb so i can play the game with no complication, i hope you can help me with this if there is a way around it, if not, let me know so i can move on..thanks
Allan_J_Intel1
In most cases, the computer manufacturer has already configured the system to use the maximum amount of graphics memory that is possible for your particular computer model.
See link below for more information:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005539.html?wapkw=video+memory Microsoft Windows 8 and 8.1* Graphics Memory FAQ for Graphics Drivers
Allan.
Hosma1
thanks allan, but i am running on windows 10 64bit , is there any llink for that ?
gbhj
the "How much graphics memory does my computer have?" section is the same for windows 10 after setting the registry value the dedicated memory may have increased to 512MB. this upper limit is set by the driver
MSchm21
When detecting the amount of available video memory for your graphics device, remember that different rules may apply to different devices. For example: An integrated graphics part reports a small amount of dedicated video memory. Because the graphics hardware uses a portion of system memory, the reported system memory is a better indication of what your game may use. This should be taken into account when using the reported memory as guidance for enabling or disabling certain features. The GPU Detect Sample shows how to obtain this information in Windows*.
https://software.intel.com/en-us/file/6th-gen-graphics-api-dev-guide-dec-2015pdf https://software.intel.com/en-us/file/6th-gen-graphics-api-dev-guide-dec-2015pdf
The dev should learn this.
