22824 Discussions
mi i5 520M no parece estar al maximo
Elpajasl0cas
Hola soy nuevo en esto de la tecnología, pero en mi PC tenía una Intel Pentium P6100 y recientemente cambié a un Intel Core i5 520M y apenas noto diferencias uno con el otro en algunos programas, y creo que debería de haber un cambio considerable, pero es literalmente imperceptible, que me recomiendan hacer? O es que literalmente no hay cambios el uno con el otro.
LeonWaksman
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
Elpajasl0cas
LeonWaksman
Hi Mira,
You have quite old model of computer. If you wont to improve its performance, in my opinion you should invest more in the hardware:
1. Increase the size of installed RAM memory 4GB (2 x 2GB) to 16GB (2x 8GB) - cost about 30$
2. Replace the installed SATA Hitachi  HDD with faster SATA SSD (Solid State Drive) - cost about 30$ for 500GB
I suggest that you should consult with Acer support about the compatibility of the replacement parts.
Take into consideration that in the next year, Microsoft will stop support for Windows 10.
Leon
Edit:
Your BIOS is outdated
