22980 Discussions
monitor and laptop dual screen resolution intel hd 4000
MMate2
Hello!
I have a lenovo z500 1366x768 laptop and a LG 1920X1080p resolution monitor. Can be solve that use i see the laptop monitor screen in 1366x768 and i see the monitor 1920X1080p dual? When i using the monitor in 1080p resolution that time the laptop screen is black. I dont wanna use extension.
Thank you for help.
Jose_H_Intel1
Hello Matt9219, if I understand your issue correctly you are attempting to set your system in clone/duplicate display mode at 1920x1080p but when you do that the laptop screen goes black, is this correct?
In case it is, I strongly suggest you updating your Intel® HD Graphics driver to the https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23885 latest version as well as the monitor driver. Then, generate the Intel® HD Graphics report and attached via advanced editor.
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
MMate2
Dear Joe,
I did what you asked.
Intel(R) HD Graphics 4000
Report Date: Friday, August 22, 2014
Report Time [hh:mm:ss]: 1:41:51 AM
Driver Version: 10.18.10.3621
Operating System: Windows* 8.1 Pro(6.3.9600)
Default Language: Hungarian (Hungary)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 8053 MB
Processor: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
Processor Speed: 2594 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2137.0
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 1
Inactive Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: CMN15b5
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 7.48 inches
Supported Modes
0 x 846 (3p Hz)
* Digital Television *
Serial Number: GSM0001
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 62.99 inches
Vertical Size: 35.43 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (60p Hz)
720 x 400 (70p Hz)
720 x 576 (50p Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1024 x 768 (60p Hz)
1152 x 864 (60p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1280 x 1024 (60p Hz)
1360 x 768 (60p Hz)
1920 x 1080 (30p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (25p Hz)
1920 x 1080 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D 01 00 01 01 01 01
01 17 01 03 80 A0 5A 78 0A EE 91 A3 54 4C 99 26
0F 50 54 A1 08 00 31 40 45 40 61 40 71 40 81 80
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 A0 5A 00 00 00 1E 66 21 50 B0 51 00 1B 30
40 70 36 00 A0 5A 00 00 00 1E 00 00 00 FD 00 3A
3E 1E 53 10 00 0A 20 20 20 20 20 20 00 00 00 FC
00 4C 47 20 54 56 0A 20 20 20 20 20 20 20 01 42
02 03 29 F1 4E 10 9F 04 13 05 14 03 02 12 20 21
22 15 01 29 3D 06 C0 15 07 50 09 57 07 67 03 0C
00 10 00 80 1E E3 05 00 00 01 1D 80 18 71 1C 16
20 58 2C 25 00 A0 5A 00 00 00 9E 01 1D 00 80 51
D0 1A 20 6E 88 55 00 A0 5A 00 00 00 1A 02 3A 80
18 71 38 2D 40 58 2C 45 00 A0 5A 00 00 00 1E 66
21 50 B0 51 00 1B 30 40 70 36 00 A0 5A 00 00 00
1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1B
* Other names and brands are the property of their respective owners.
MMate2
And i have another very importent problem.
"On a digital connection (such as http://en.wikipedia.org/wiki/Hdmi HDMI) to a monitor or television this can result in grey looking blacks and washed out colours.
This article describes how to extended the driver settings to the full range on a per-user basis, so that full colour rendering is restored."
http://www.sigma-uk.net/wiki/tech/ubuntu_intel_hd_rgb Intel HD Graphics Full RGB Rendering [Sigma Consulting Services]
My operation system is Win 8.1, not linux. What should i change in registry for work Full RGB?
Anyone, who want FullRange RGB HDMI output on http://www.sears.com/shc/s/p_10153_12605_00348690000P Intel Graphic may try this:
1. Find your current http://www.sears.com/shc/s/p_10153_12605_00348690000P Intel Graphic Adapter software registry instance under:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\xxxx
(0000 on my PC).
2.Create DWORD value:
EnableRGBFullRange
and set it to 1
3. Reboot.
4. Enjoy.
This method work?
Thank you for your anwers and sorry for my bad english.
Jose_H_Intel1
If you want to set up clone or duplicate display instead of extended mode I suggest you using a screen resolution supported in common by both the built-in monitor and the external monitor/TV.
The laptop's monitor supports 1366x768 but will not likely support 1920x1080. On the other hand the report indicates the TV does not list 1366x768 as a supported screen resolution, hence the recommendation above.
In regards of your second question, is the cable that you are using HDMI only or is it some type of adapter or converter?
MMate2
Jose_H_Intel1
The method you described above has not been validated. We do not recommend that type of modifications. However, you can try these steps instead:
  • Reset monitor settings to default or test with a different monitor/TV/HDMI cable.
  • Reset Intel® HD Graphics default settings by pressing Ctrl Alt F8.
  • Do a clean installation of the Intel® HD Graphics driver by first uninstall it from Programs and Features, restart, and then remove it from Device Manager. After another restart you can install the latest version.
  • Update your system BIOS.
Remember you can test the driver provided by the system manufacturer since it was tested with your computer model.
