23822 Discussions
my graphics driver isnt working
kiddjayy
i been having issuse playing fortnite for thr past 3 years on mt hp computer it dont seem to be working all the time i need help updating all my computer stuff
AlHill
Since you provided no information, So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[AI is the same as snake-oil]
RedCapsicum9
New Contributor II
If Fortnite’s giving you performance issues, check out this article: Performance Issues with Fortnite on Intel® Arc™ Graphics*. If you’re looking to update your graphics, here’s a helpful guide: How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11*. Also, don’t forget to run SSU as mentioned by @AlHill  to check your graphics setup.
