23801 Discussions
...need Help ! Intel GMA945 Graphics driver
... hello,
for my new project I need a special resolution. I have a QBox 1010 with N270 chipset and Intel GMA945 graphics card. This fanless computer I need to use as CAR PC. But the CAR interface requires a 50Hz PAL-Resolution of 768x576i / interlaced mode.
The Car-PC runs with WinXP32bit.
The video card driver does not support this mode. Even with PowerStrip I get this resolution / the interlaced signal is not set because the graphics card successfully defends.
With my laptop and power strip and a VGA output on the CAR interface it works fine. So it is only to the GMA945 chipset who makes this problems.
Can someone write a driver or give me advice?
In this problem, I need urgent help, because the realization threatens to fail just on this one issue.
Thanks for the help!
Allan_J_Intel1
Hi Ricky,
Intel does not provide assistance customizing screen resolutions. You will need to contact the computer manufacturer for any customized driver for your computer model.
Allan
