23717 Discussions
need help with which driver i need
here is some info on my VGA i cant seem to find anything on the download centre and my computer wont load the auto run download on the download centre everything i have found is for xp and says my OS is not good enough to run the installer but before i had Intel(R) Extreme Graphics working
Video Adapter PropertiesDevice DescriptionStandard VGA Graphics AdapterAdapter StringVGABIOS StringHardware Version 0.0Chip TypeIntel(r)845G/845GL/845GE/845GV Graphics Chip Accelerated VGA BIOSDAC Type8 bitInstalled Driversvga (6.0.6001.18000 (longhorn_rtm.080118-1840)), framebuf (6.0.6001.18000 (longhorn_rtm.080118-1840)), vga256 (6.0.6001.18000 (longhorn_rtm.080118-1840)), vga64k (6.0.6001.18000 (longhorn_rtm.080118-1840))Memory Size832 KB
BF_
New Contributor II
There is no Vista driver for it, but you should be able to get the XP one working.
There seem to be two ways:
1 ) Yes, it says Windows 7, but for your purposes there's no difference:
http://techiesrahul.blogspot.com/2011/07/how-to-install-intel-82845g-graphics.html /* Life Runs on Code */: How to Install intel 82845G graphics driver on Window 7
2) Download the EXE version. Right-click it in Explorer, select Properties, access the Compatibility tab, and select Windows XP SP2. OK that and run it. Reboot afterwards.
http://downloadmirror.intel.com/9033/a08/win2k_xp14103.exe http://downloadmirror.intel.com/9033/a08/win2k_xp14103.exe
BTW, if you have Vista x64, I think you're out of luck but I'm not sure. If you have x86, you should be fine.
Thank you i will have a look at what you have given me and yes i am running the 32bit version of vista
