23832 Discussions
no audio drive found
sta05
I have reloaded windows from a fresh download
The audio does not work I tried 3 different drive scans but it could not find the audio driver or manufacture of th
board  to download driver .
I opened the laptop because no serial or laptop name was on the case, I copied the name of the mother board
  y116te-E_APL_LP3B216_v2po motherboard but could not find a manufacture
I did find a number on the side of the laptop
Time of this report: 6/14/2025, 11:21:15
Machine name: DESKTOP-TU8V4JV
Machine Id: {35B1CB21-9608-42F1-BC4A-8F13D4F13948}
Operating System: Windows 10 Home 64-bit (10.0, Build 19045) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Default string
System Model: Default string
BIOS: Y116TE.E.L3B216.2Z9.6D.S2W6A1F0.DX.Intel.k006 (type: UEFI)
Processor: Intel(R) Celeron(R) CPU N3350 @ 1.10GHz (2 CPUs), ~1.1GHz
Memory: 6144MB RAM
Available OS Memory: 5978MB RAM
Page File: 4999MB used, 2641MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.5794 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 500
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_5A85&SUBSYS_22128086&REV_0B
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 3116 MB
Dedicated Memory: 128 MB
Shared Memory: 2988 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.625000,0.339844), Green(0.285156,0.605469), Blue(0.148438,0.062500), White Point(0.281250,0.308594)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Digital Flat Panel (640x480 60Hz)
Monitor Model: SC40DC30D1465
Monitor Id: MS_0001
Native Mode: 1366 x 768(p) (59.994Hz)
Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_dca7f3f6531ce13b\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_dca7f3f6531ce13b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_dca7f3f6531ce13b\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_dca7f3f6531ce13b\igd12umd64.dll
Driver File Version: 31.00.0101.2134 (English)
Driver Version: 31.0.101.2134
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Hardware Scheduling: Supported:False Enabled:False
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Detachable GPU: No
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Not Supported
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 20/11/2024 10:00:00 AM, 1739968 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-19C5-11CF-60EB-7702A4C2D235}
Vendor ID: 0x8086
Device ID: 0x5A85
SubSys ID: 0x22128086
Revision ID: 0x000B
Driver Strong Name: oem39.inf:5f63e53438f3d47b:iBXTD_w10_DS:31.0.101.2134:PCI\VEN_8086&DEV_5A85
Rank Of Driver: 00CF2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 {E07EC519-E651-4CD6-AC84-1370CCEEC851} {BCC5DB6D-A2B6-4AF0-ACE4-ADB1F787BC89} DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT {C528916C-C0AF-4645-8CB2-372B6D4ADC2A} {91CD2D6E-897B-4FA1-B0D7-51DC88010E0A} DXVA2_ModeVP8_VLD {442B942A-B4D9-4940-BC45-A882E5F919F3} {97688186-56A8-4094-B543-FC9DAAA49F4B} {1424D4DC-7CF5-4BB1-9CD7-B63717A72A6B} {FFC79924-5EAF-4666-A736-06190F281443} {2364D06A-F67F-4186-AED0-62B99E1784F1} {28566328-F041-4466-8B14-8F5831E78F8B} {8C56EB1E-2B47-466F-8D33-7DBCD63F3DF2} DXVA2_ModeHEVC_VLD_Main {75FC75F7-C589-4A07-A25B-72E03B0383B3} DXVA2_ModeHEVC_VLD_Main10 {07CFAFFB-5A2E-4B99-B62A-E4CA53B6D5AA} {76988A52-D_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB
MPO Stretch: 5.000X - 0.334X
MPO Media Hints:
MPO Formats: YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB
PanelFitter Stretch: 5.000X - 0.334X
Component Drivers:
Driver Name: Unknown
Driver Version: Unknown
Driver Date: Unknown
Driver Provider: Unknown
Catalog Attributes: N/A
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 1
FriendlyName: USB Camera
Category: Camera
SymbolicLink: \\?\usb#vid_32e6&pid_9005&mi_00#6&28c7ad2c&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: 0
Manufacturer: Microsoft
HardwareID: USB\VID_32E6&PID_9005&REV_0001&MI_00,USB\VID_32E6&PID_9005&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.19041.5915
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 21/06/2006 12:00:00 AM
Service: usbvideo
Class: Camera
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: USB Camera
Parent: USB\VID_32E6&PID_9005\5&27435a1f&0&8
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: WdmCompanionFilter
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: n/a
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
CustomCaptureSource: n/a
DependentStillCapture: n/a
EnablePlatformDMFT: n/a
DMFTChain: n/a
EnableDshowRedirection: n/a
FrameServerEnabled: n/a
AnalogProviders: n/a
ProfileIDs: n/a
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HIDI2C Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0911, 0x5288
FF Driver: n/a
Device Name: Intel(R) HID Event Filter
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x8087, 0x0A1E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Converted Portable Device Control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0000
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Stephen
AlHill
Please stop before you damage your laptop.
Who made the laptop, and what is the laptop model number?
The manufacturer will have the drivers you need.
And, you need more than just the audio driver.  You need to install the Intel ME as well, and likely you need to run the chipset software installer.
If you cannot answer the above questions, do this:
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[This is the dawning of the age of Colossus, where peace is compulsory, freedom is forbidden, and man’s greatest achievement is man’s greatest mistake.]
AlHill
Also, this driver may help you:
https://www.intel.com/content/www/us/en/download/18799/intel-graphics-driver-for-windows-15-45.html
sta05
Thank you for your reply
I have run software to find out who the manufacture is  all  I get is this
 I have opened the laptop because no serial or laptop name was on the case, I copied the name of the mother board
There is only a number on the side of laptop  which I have included in my orig post plus a photo of the motherboard
I will try the link you sent me when I get away from work
AlHill
Run the ssu report as I asked and attach the results.
sta05
