23741 Discussions
no ethernet controller
I bought a motherboard (rampage 3 extreme) there a few days and i installed windows seven 64 bits. The ethernet controller (82566-DC 2) is recognized as hardware but there was an exclamation point next to hardware and I have a error code 10. I installed the latest driver (15.5) but still the same result.
Looking at the irq, I have (PCI) 0xFFFFFFFB (-5) Port racine Intel (R) 5520/5500/X58....-340E
(PCI) 0xFFFFFFFC (-4) Port racine Intel (R) 5520/5500/X58....-3409....
Is this normal ? I don't have internet and I don't know what to do...
Config :
I7 950
R3E
Harddisk 2To
GTX 460
Nounours0000
If you shutdown and unplug the the network cable when you boot back up is error code 10 still their?
I suggest you try the drivers from Asus as you might have got the wrong ones even if you did get the right ones.
http://support.asus.com/download/download.aspx?model=Rampage%20III%20Extreme&f_name=Intel_LAN_V10160_XpVistaWin7.zip&f_type=5&os=30 http://support.asus.com/download/download.aspx?model=Rampage%20III%20Extreme&f_name=Intel_LAN_V10160_XpVistaWin7.zip&f_type=5&os=30
I have always code 10 (the device can't start) with asus driver. In tab ressources, it writes :"This device uses no resources because it has a problem"
The LEDs that are normally green and orange are extinct. At PC startup, an orange LED lights up and then nothing.
In everest software:
Nounours0000
Have you installed the chipset drivers? With -overall command if possible.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=18494&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel®+Chipset+Software+Installation+Utility&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=18494&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel%c2%ae+Chipset+Software+Installation+Utility&lang=eng
Try the motherboard out of the case on some cardboard.
If you still get a error and you done what a asked then the connections from the Ethernet controller to the port is likely damaged and you will have to get a replacement motherboard.
