23095 Discussions
not reaching the minimum limit after reinstalling drivers
AAlak
i tried to fix a problem that was appearing once i open any game on my pc and i ended up deleting my intel driver (it was  Intel® HD Graphics P630 ) now everytime i try to reinstall it it shows a massage saying that my pc do not has the minimum limit for it.
so what should i do for it ??
AlHill
What is the exact model number of your processor?
What is the version and build of your operating system?
Doc
AAlak
i have a windows 10 with intel core i7-7700
AlHill
Ok, but what version and build of Windows 10?
Is this a laptop or desktop?
Doc
AAlak
windows 10 home x64-bit, it is a desktop
AlHill
Ok, that is still not the version and build, but we will work with it.
The drivers for your graphics can be found here:
https://downloadcenter.intel.com/product/97128/intel-core-i7-7700-processor-8m-cache-up-to-4-20-ghz
if you are trying to install the DCH driver, you must remove ALL previous driver installations.
You can use my procedure here: https://forums.intel.com/s/question/0D50P00004Fm2ngSAB/how-to-install-the-dch-driver?language=en_US
If you are not trying to install the DCH driver, you might try installing the latest STANDARD driver using the manual method.
https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
All of this is assuming you are not running any pre- release of Windows 10, and are on version 1809.
Doc
Wanner_G_Intel
Hello AAlak, Were you able to perform the steps recommended? Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
