23780 Discussions
overclocking for ARC A770
sabitispro
What should be the best overclocking present for  a770 gpu - my gpu just crashes when i tune up something and run stress test. I just want to play fortnite. Thanks.
Mike_Intel
Hello sabitispro,
  1. Can you tell me how did you overclock your Arc A770?
  2. What is the issue that you encounter with Fortnite running while running on default settings?
  3. What are the troubleshooting steps that you tried so far?
  4. Can you share some screenshots and video of the gameplay and during the overclocking?
Michael L.
sabitispro
I overclocked my setup using the Intel graphics software. When I was playing at the default settings, I wasn’t getting the FPS I expected—barely hitting around 100 FPS even on the most minimal graphics settings. After messing around for about an hour, I finally found a stable preset, but I'm still not getting enough FPS out of it.
In addition - Is there any way to boost memory clock in arc gpus?
Mike_Intel
Hello sabitispro,
Thank you for the quick response.
It is hard to provide recommendations or guides for overclocking since different system may have different behavior and output.
I can only share this link below and take note that overclocking may damage or shorten the life of the device.
How Can I Overclock My Intel® Arc™ GPU Using Intel® Arc™ Control?
I know you are using the Intel Graphics Software however I hope you get the idea. You may need to do a lot of trial and error to get to a stable setting.
Michael L.
Mike_Intel
Hello sabitispro,
Michael L.
sabitispro
Hi Michael,
Apologies for the late reply! I checked out the article, and despite the warning, I've been overclocking my GPU for a few days now. I think I’ve nailed down a pretty solid preset: VO -55mv, CPL - 226V, and PB - 32%. So far, no crashes or driver issues, and I'm actually planning to stick with this setup until it gives out—haha! But honestly, I don't think that’s happening anytime soon. My temps are hanging around 122F and peak at 161.6F during stress tests, which seems pretty decent based on some other articles I’ve read.
Thanks a ton for your support; I really appreciate it!
Do you know when we can expect the driver update for Xess 3?
Thanks!
KentRusselP_Intel
Hi sabitispro,
Thank you for your confirmation. I hope this message finds you well! On behalf of my colleague, I would like to inform you that overclocking your device may cause damage or reduce its lifespan. Please exercise caution when considering this option.
Regarding your inquiry about updates for XeSS, we kindly ask you to stay tuned and regularly check our official Intel Newsroom Home for the latest and exciting announcements.
Finally, I will proceed to close this inquiry. Should you need further assistance or have additional questions, please do not hesitate to submit a new request. Kindly note that this thread will no longer be monitored once it is closed.
Kent Russel P.
