22944 Discussions
problème de mise à jour intel corporation update intel graphic 3000
DVAND31
bonjour,
depuis hier j'ai une mie à jour intel sur Windows upodate et je n'arrive pas à la faire. j ai le code erreur 800170103.
Est-ce normal? qui peut m'aider?
merci
ps : je suis sous Windows 8.1
Silvia_L_Intel1
Hello Dunkan, since you are experiencing this behavior just after the a Windows Updated, what you can try is restoring your computer to the last working state by choosing "System Restore" once you're in Windows.
Also, you can try to install the previous graphics driver or make sure you have the latest one?
You can also try removing the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
