23077 Discussions
problema con Intel HD gráficos 520
Erown
Mi ordenador tiene esos gráficos que resultan antiguos para ciertos juegos, como Fortnite. Me recomienda descargar una versión más actualizada, pero no hay y no encuentro gráficos mejores que lo sustituyan. Alguien sabe que gráficos valdrían?
Dejo las especificaciones del dispositivo aquí.
n_scott_pearson
The latest version of the driver package supporting your processor can be downloaded from here: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html. Try installing it and see if it resolves the issues.
Hope this helps,
Erown
Gracias por el enlace, pero la descarga es hasta windows 21h2 y yo tengo 22h2, asique no me funciona.
n_scott_pearson
Anything that works with 21H2 should work with 22H2. When Intel mentions OS versions in their Release Notes, they are simply detailing what they tested it with, not what it will actually work with. Did you try it or did you just discard it out of context? In operation, if the games are complaining about the graphics, there are two possibilities, (1) they are older games that have a bug in their handling of Intel's version strings, or (2) they simply require a better graphics solution to be played reasonably.
As for a replacement graphics solution, you didn't provide any information regarding your system type. Your processor would seem to indicate that you have a desktop PC, but we really cannot be sure. If it is a desktop, there are *many* graphics cards that would work with it. This includes, for example, the NVIDIA GTX 10 SeriesNVIDIA GTX 16 Series, and the NVIDIA RTX 20 Series. Which you choose is up to you...
Hope this helps,
