22819 Discussions
probles with update Drivers for plus graphics 640
DLevy1
hello
I have a Dell P2415Q (DP4K60) monitor connected to a Surface Pro (newest version) Intel Core i7 / 512GB SSD / 16GB RAM via display port through a Surface Dock. I'm running Windows 10.
i have Intel Iris Plus Graphics 640
If I run an 'extended' desktop, the external monitor will blink off then on frequently to the point of being unusable. This behavior seems to occur coincident with an action in another program like clicking a link in a browser. However, it will also occur when the cursor is idle.
someonr told me i should update the graphics drivers
Intel® Graphics Driver for Windows
Version: 15.65.4.4944 (Latest) Date: 2/13/2018
https://downloadcenter.intel.com/download/27484/Intel-Graphics-Driver-for-Windows-15-65- https://downloadcenter.intel.com/download/27484/Intel-Graphics-Driver-for-Windows-15-65-
but i tried to install it and i got a massage i cant install it on the computer so i trued to do it manually but it didnt install them
what should i do?
Hello Doron10011
Thank you for joining the community.
Allow me to share with you that Intel® does not recommend the use of any kind of adapters. This is because we cannot test all of them, so we cannot guarantee that these are going to work. We can recommend you to update your graphics driver that in some cases will fix the problem.
To update the drivers manually please follow these steps in order to update the graphics driver:
  1. Download the graphics driver ZIP file: https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.zip https://downloadmirror.intel.com/27484/a08/win64_15.65.4.4944.zip
  2. Unzip the file to a designated location or folder.
  3. Right-click Windows Start icon and open Device Manager.
  4. Click "Yes" when prompted for permission from User Account Control.
  5. Expand the Display adapters section.
  6. Right-click the Intel® graphics entry and select Update Driver Software.
  7. Click "Browse my computer for driver software".
  8. Click "Let me pick from a list of device drivers on my computer".
  9. Click "Have Disk".
  10. Click "Browse".
  11. Access the designated location or folder, and access a folder called "Graphics".
  12. Select the file called "igdlh64" or "igdlh".
  13. Click Open, then click "OK", and finally click Next. Drivers are now being installed.
  14. Reboot your computer.
  15. And let me know if you have any issues with the installation.
If the generic drivers don't help on the situation you can also try the drivers from Microsoft.
https://support.microsoft.com/en-gb/help/4023482/surface-download-drivers-and-firmware-for-surface https://support.microsoft.com/en-gb/help/4023482/surface-download-drivers-and-firmware-for-surface
Please be aware that the content on that site is not controlled by Intel®. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
In case these updates don't help on the problem we recommend contacting the manufacturer for assistance setting your configuration.
https://support.microsoft.com/en-gb/contactus/ https://support.microsoft.com/en-gb/contactus/
Leonardo C.
DLevy1
Hello Leonardo C
first of all thank for the help
so DELL try to help me and change for me the monitor to other model it is a 4k monitor U2718Q and i just gor it today
and now i have the same problem like before just i have it a little bit less then it was in the other screen.
but it means that the problem is not with the monitore it is somthing with the Graphics Card
so still i want to try to install the Drivers and mayby it will solve my problem
so i tried to follow your staps but i have a problem with the installation.
when i unzip the zip file and then brows and go to Graphics
i dont find the file called "igdlh64" or "igdlh".
and then i notice i can only choose files with a ".inf" and i saw that this file is there but just without the ".inf"
so i add manually ".inf" to the file and then i could choose him. but still i tried to keep the steps but i gor an error messege that i cant install the Drivers because "This driver is not digitally signed"
and when i click "next" i have a massage "The thirs-party INF does not contain digital signature information"
so what can i do?
you sure this Drivers is ok for my computer new surface pro?
i dont understand why Intel Iris Plus Graphics 640 is not working with external 4k monitor
thank you
Doron.
Stefan3D
Extension INF is obfuscated in Windows by default.
So you actually renamed the file to igdlh64.inf.inf
Open Explorer options and untick "hide extensions"
DLevy1
no cus if i do it i getting ".cat" and no ".inf"
why i cant install this Driver?
Stefan3D
Restore the original name of the INF file you have messed up and select it.
The CAT file contains the digital signature which had failed because of the renaming you had done.
DLevy1
no no but then i cant install the Drivers
because in step number 12
when you said "
  1. Select the file called "igdlh64" or "igdlh".
i dont find the files so i cant choose that file
and it happen because when i brows i just can choose files with .inf
and the this file is without it
Stefan3D
In spite of changing the aforementioned Explorer option?
DLevy1
no i didnt change nothing if i download a new Driver from the link you gave me i get the files with a .cat without any change i did
and i cant install this Driver....
what can i do?
Hello Doron10011
Thank you for your response.
Could you try the steps provided previously using this version of drivers https://downloadmirror.intel.com/27650/a08/win64_15.65.5.4982.zip https://downloadmirror.intel.com/27650/a08/win64_15.65.5.4982.zip?
Hope this helps.
Leonardo C.
Hello Doron10011
I was checking your case and would like to know if you had time to try de driver installation.
Leonardo C.
DLevy1
hello so yes i succeed to install the driver
it was in the folder other file that you didnt say i should try to choose and install but it was with a".inf" at the and so i just try and
it worked well and then i install the Driver
so then i didnt had any problem at all
it works find until now with my monitor.
but actually few days ago i connected my computer to a Samsung TV with a HDMI cable throw a Mdp to HDMI adaptor that i order in ebay and then i had again the same problem that the screen goes black randomly foe few second and then come back.... it happen less then it happen before cut it still happen while i watched a movie.
any way most of the time i using my monitor Dell U2718Q and after i install that driver i didnt have any more problem so i'm happy enough.
by the way i saw that there is another update for the driver i can do but i just prefer dont touch it any more cus right now it works well for me...
thank you very much
Doron.
CMill41
I have the same problem with a Surface Pro 5 i7 !!
I' using a benQ 4k monitor and the external display is
switching off every 10-15 sec mostly when I change tabs or scrolling a lot, or
when a lot is going on the display!
A few things that I checked:
It happens also without the Surface Dock when I hook up the Monitor directly to my Surface
It doesn’t happen with the Surface Pro 5 i5 version of the Surface when using the same Hardware (monitor and cable)
The difference between the i5 an the i7 version is the internal Graphics chip the i5 is using a Intel HD 620 which is working just fine!
I could reduce the black screens significantly by reducing the refresh rate of the external monitor connection to 4k 50 Hz…. When I change it back to 59 Hz it is not usable anymore!
I don’t think the cable is the problem because the i5 Surface is working fine with 4k / 59 Hz!
I also found other users all over the net with the same problem, the problem is definitely with the Iris 640 driver or standard setting!!!
https://forums.windowscentral.com/windows-10/499330-random-black-screen-1-2-seconds-when-connected-4k-monitor-surface-pro-2017-a.html
https://www.drwindows.de/microsoft-surface/166692-surface-pro-i7-problem-zwei-externen-bildschirmen.html
CMill41
I added a topic on the Microsoft Feedback-Hub, maybe you could add a comment and give the topic more weight.
https://aka.ms/AA8c2ub
CMill41
It's seems to be a old, very well known problem with the Surface Line and the Iris graphics!
https://answers.microsoft.com/en-us/surface/forum/all/surface-pro-4-external-screen-keeps-turning-onoff/654b70c9-2734-4eaf-8ddb-d5b4c25a1820?page=17
Why is there still no driver fix?!
