22755 Discussions
"does not meet minimum requirements message.
rlawr
Hi there, i have a fangbook evo from cyberpower PC and recently reinstalled windows 7 64-bit to it. The driver disk they gave me is giving me issues, and whenever i open the VGA folder and run the intel graphics drivers install, i get a message saying "system does not meet minimum requirements to install" or something of the sort. I've tried running the intel driver update utility, but it fails to find anything- even when i do as the troubleshooting suggests. I'm not sure if i'm missing drivers, or what, but at this point, I've run of ideas for fixing it, and would appreciate any help.
My processor is a: intel(r) core(tm) i7-4810mq cpu @2.80 Ghz 2.80 Ghz
GZimm1
Same issue here with Windows Technical Preview. The latest Intel HD Graphics (3960) refuses to install with either the Setup executable or manually. Windows update also lists this driver as available for installation, but after downloading reports an error message that the update failed.
Kevin_M_Intel
Can you please try the steps mentioned here?
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Kevin M
GZimm1
I was able to manually install the Intel HD Graphics drivers by:
- Deleting the reference to Threshold in the configuration file that prevented installation with Windows Technical Preview
- Modifying the first line in the Windows 8.1 setup section header to [IntelGfx.NTamd64.6.4]
- Restarting in Windows Troubleshoot mode to allow installation of drivers not digitally signed
Cheers
