23790 Discussions
résolution
izuna
bonsoir en fait je n'arrive pas a trouver la résolution de mon second écran toute les résolution disponible ne conviennent pas a mon second écran il y a toujours des cotés noir donc merci de m'aider ^^
AlHill
Provide the model number and manufacturer of your moniters.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
