23262 Discussions
screen resolution change when turn off monitor
Hi, I captured it and you can see it here http://dl.dropbox.com/u/54513180/screen%20resolution.avi http://dl.dropbox.com/u/54513180/screen%20resolution.avi
Somehow, everytime i switch off my monitor, the screen resolution will change to smaller size.
When I turn on, it will change back. The is frustrating as some program or icons will shift.
Is there anyway to let it not change the screen resolution when i switch off my monitor?
Am using G2020 intel processor build in graphics with the latest driver.in windows 8 64bit g, as shown here
http://i.imgur.com/0dEkyHV.png http://i.imgur.com/0dEkyHV.png
done a second test show that monitor disappear after switching off as shown
it will reappear after turning on
http://dl.dropbox.com/u/54513180/test2.avi http://dl.dropbox.com/u/54513180/test2.avi
wonder why it is like that after i change to dvi instead of vga
Allan_J_Intel1
The problem is that your processor is first generation graphics, in other words, Intel HD Graphics and you are using Windows* 8. In this case, you have loaded Windows generic drivers that are inbox drivers, they do not contain all proper features for your graphics controller.
Please bear in mind Intel did not develop drivers for Intel HD Graphics running Windows* 8. Your graphics controller supports full windows 7 32 or 64 bit.
See here for more information:
http://www.intel.com/support/graphics/sb/CS-033838.htm http://www.intel.com/support/graphics/sb/CS-033838.htm
My cpu is ivy G2020 with intel hd graphic, driver is latest available
as shown below and not generic drivers.
Product Detectedhttp://www.intel.com/support/graphics/sb/CS-033849.htm Intel® HD Graphics 2500 or Intel® HD GraphicsCurrent Driver Installed9.17.10.2932Your driver is current.
This is very annoying bug in Windows.
My config:
Windows 8 Pro (64-bit),
Intel HD Graphics 3000,
NEC MultiSync PA231W via DisplayPort.
I have this bug since Windows 7. In my case, according to http://support.microsoft.com/kb/2625567 http://support.microsoft.com/kb/2625567, it's related to DisplayPort. Nothing changed in Windows 8.
i switch to dvi and this problem persist, when using vga it is ok
not sure why but this is annoying
Allan_J_Intel1
I will forward this thread to the engineering department, if more information is needed, I will come back here and post some updates.
Allan.
NICHOLAS_F_Intel
Hi Stanley & Andrey,
Have you updated to the latest drivers for your configuration?
Stanley: Download this driver here; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22605&lang=eng Download Center
Andrey: Download this driver here; https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22628&lang=eng Download Center
Let me know if after upgrading your drivers, this issue is still happening.
Also, @Stanley, if you can clarify for me please; I'm looking at your .AVI video.. the first resolution is when it is running normally, the second resolution is when you turn the display off and then back on, and the last resolution is after it automatically adjusts to the right size again, correct?
-Nic
NICHOLAS_F_Intel
Also, can both of you provide a copy of your DxDiag's (Start -> Run -> Dxdiag -> Save All Information) and your Intel® Graphics Driver Report (Ctrl + Alt + F12 -> Options & Support -> Information Center -> Save)
Just post them here so I can take a look!
Thanks again,
-Nic
Hi Nic,
yes, I'm using the latest drivers.
Actually, some time ago I found a sort of solution http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/4d8f3aef-8c04-481b-a69a-ec0fbf3669c2/ here (RMNixon's post by Saturday, June 16, 2012 5:41 AM).
Dxdiag
System Information
Time of this report: 4/24/2013, 20:54:26
Machine name: ANDREY-PC
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130306-1502)
Language: Russian (Regional Setting: Russian)
System Manufacturer: INTEL_
System Model: DZ68DB__
BIOS: DBZ6810H.86A.0043.2012.0615.2054
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8100MB RAM
Page File: 5347MB used, 3152MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0122&SUBSYS_201B8086&REV_09
Display Memory: 1664 MB
Dedicated Memory: 32 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: NEC MultiSync PA231W(DisplayPort)
Monitor Model: PA231W
Monitor Id: NEC67E5
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Displayport External
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3062 (English)
Driver Version: 9.17.10.3062
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: 3/8/2013 19:10:18, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4262-11CF-C0E8-1100B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0122
SubSys ID: 0x201B8086
Revision ID: 0x0009
Driver Strong Name: oem40.inf:5f63e534f67086e7:iSNBD0:9.17.10.3062:pci\ven_8086&dev_0122
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_E...
Driver report:
Report Date: 4/24/2013
Report Time[hh:mm:ss]: 21:01:49
Operating System: Windows 8 (6.2.9200)
Default Language: Russian (Russia)
DirectX* Version: 11.0
Physical Memory: 8099 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 3392 MHz
Vendor ID: 8086
Device ID: 0122
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2132.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
* Digital Display *
Monitor Name: NEC MultiSync PA231W DisplayPort
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 20,08 inches
Vertical: 11,42 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (75 Hz)
640 by 480 (72 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 720 (60 Hz)
1360 by 765 (60 Hz)
1400 by 1050 (60 Hz)
1440 by 900 (60 Hz)
1600 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 38 A3 E5 67 00 00 00 00
10 15 01 04 B5 33 1D 78 E2 08 65 A3 56 4C 9E 25
11 50 54 BF EF 80 81 C0 81 40 81 80 8B C0 95 00
90 40 B3 00 A9 C0 02 3A 80 18 71 38 2D 40 58 2C
45 00 FE 1F 11 00 00 1E 00 00 00 FD 00 32 55 1F
53 10 00 0A 20 20 20 20 20 20 00 00 00 FC 00 50
41 32 33 31 57 0A 20 20 20 20 20 20 00 00 00 FF
00 31 34 31 30 32 31 37 37 55 42 0A 20 20 00 A5
* Other names and brands are the property of their respective owners. *
NICHOLAS_F_Intel
Hi Andrey,
Can you provide a description of your systems behavior post-workaround?
-Nic
Hi Nic,
after this workaround I just have no problem with resolution change after turning off my monitor. I have changed in the registry the default resolution (1024x768) to the resolution of my monitor (1920x1080). Since the default resolution and screen resolution are the same now there is no problem. But this is definitely a workaround, not a proper solution.
seems logical, intel should change the default resolution in the registry too with the new driver unless they have a better solution to it
