23834 Discussions
shader mod 3
gfran5
hello , i have a problem with my grapihcs card . a game said me i haven t shader 3 but on intel website i do have it in my configuration ? i have a intel hd graphic i3 380M 2.54gh . can you helpme please , thank you
Stefan3D
Go to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html Supported APIs and Features for Intel® Graphics Drivers and unfold "Determining Graphics API Information"
I would like to have additional information about your system configuration. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
gfran5
thank you for your help !!
gfran5
i have not the information of the shader mod ?
gfran5
what is the difference in shader mod 3 4 or 5 ?
Thank you for the attachments.
Shader model for your graphics controller would be version 4.0. This is enabled once you install the latest graphics drivers for your graphics controller.
For Shader information please check this https://en.wikipedia.org/wiki/High-Level_Shading_Language link
Allan,
gfran5
can you find me the latest driver driver for my graphics controller plese ?
Were you able to test Intel® HD graphics for Windows® 7?
Allan.
gfran5
hello , i have try with your latest driver and it s the same : shader model 3.0 is requierd...
That's unfortunate. At this stage, I recommend checking with Toshiba for customized drivers for your computer model, the generic drivers loaded from Intel do not appear to enable Shader model, therefore, I think you need drivers directly from http://support.toshiba.com/ Toshiba
Allan.
gfran5
yes ,i know. i have search on the intel site web for latest driver and anyone can install, for my graphic card your latest driver are for linux ... on google nothing too .
