23852 Discussions
specific GPU driver for HD5500?
Please kindly help...
I got Intel HD Graphics 5500 within my PC.
When I tried to run TurboCAD, it shows the following
" TurboCAD 2015 has detected that it does not have a specific driver for the Graphics Processor Unit (GPU), or Graphics Board on this computer. This is most likely because the GPU is too new, or too old. As a result a default driver will be used while in RedSDK mode"
" To provide the optimum results from RedSDK it is recommended that a driver supported GPU-accelerator be used."
I checked the driver installed is 20.19.15.4531 (2016/9/29) in OS system info.
Within TurboCAD, the video system info shows the following...
Hardware vendor: Intel
Renderer: Intel(R) HD Graphics 5500
GPU chipset: Unknown
OpenGL version: 4.4.0 - Build 20.19.15.4531
Just wonder how can I fix this problem (instead of skip this warning)? any specific driver I should installed?
Thanks in advance.
Best Regards
Simon
Hello Outerlimits,
At this point, your best support is the software developers of TurboCAD 2015, also you will need to check the minimum system requirements for this software.
As well, you can use the information from the link provided by Stefan3D.
Ivan.
