20638 Discussions
speckles in win7 title bar
On my Lenovo T420 with the latest 3000 HD driver I am seeing a ghosting speckle in the title bar. Here is a screen clipping:
Has anyone else seen this issue? Perhaps a resolution?
Cheers,
-- miles
DArce
Valued Contributor III
The speckles that you are seeing are due to the Windows* color scheme that you are using.
What you need to do is to check on the Windows* options to enable the aero glass transparency effects on your system. That is usually available in the Control Panel, under or right click on the desktop, click on Personalize, then go to the Window Color and Appearance Option
