23833 Discussions
system_service_exception igdkmd64.sys
JTurc1
Every time I am trying to connect a monitor to the HDMI port "I have the following error message : system_service_exception igdkmd64.sys . They have 2 HDMI post behind the computer 1 is on the graphic card and the other seam to be from the PC. If I use the other (not on graphic card) the pc will crash few minute after I connect a screen to this port but it will work well before crash.
My Computer Spec :
Asus ROG G20 Desktop PC i7 12GB 1TB NVIDIA GTX750
- CPU : Intel® Core™ i7-4790 (8M Cache, up to 4.00 GHz)
- VGA : NVIDIA® GTX750 2GD5
- OS : Windows 8.1
- Memory : 12G DDR3 1600MHz
- Storage: 1TB SATA (100G ASUS westorage 1years)
- ODD : Blu-Ray 8X Combo
- LAN : 10/100/ 1000 Mbps
- Audio : 8-channel Audio SonicMaster
- Card readerN/A
- Front I/O
- USB3.0 x 2
- Mic Port x 1
- Earphone port x 1
- back I/O1 x RJ45 LAN, 1 x HDMI-Out
- 1 x 8 channel Audio
- 2 x USB 3.0 4 x USB 2.0
- 2 x Power jack
- power supply: 230WAdapter
- certificates : BSMI/CB/CE/FCC/UL/CCC/Energy Star/VCCI
Graphic Card Spec:
http://www.asus.com/Graphics_Cards/GTX750PHOC2GD5/specifications http://www.asus.com/Graphics_Cards/GTX750PHOC2GD5/specifications
Silvia_L_Intel1
JoelTG, could you please attach the DX Ddiag report from your system so I can check the current information?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Attach using Advanced Editor Options.
JTurc1
Hi there,
Thanks you for trying to help me, I have attached the file you requested to this post.
Silvia_L_Intel1
JoelTG, since your system has Switchable Graphics it is important to find out on BIOS which is the primary Video port. Sometimes when using a single monitor and if the video card was set as primary video source, the monitor needs to be connected to it.
I will also recommend you to install the graphics drivers again. On a system with switchable graphics it is necessary to install the Intel graphics drivers first and then Nvidia's.
This link will take you to the latest Intel drivers available for the HD4600
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348&lang=eng&ProdId=3720 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348&lang=eng&ProdId=3720
See the link below for more information about switchable graphics: http://www.intel.com/support/graphics/sb/CS-031103.htm Graphics Drivers — Switchable Graphics Feature FAQ
JTurc1
Pleases explain me how to uninstall my current driver, because I don't know how to do it .
I am also really disappointed by Asus.
JTurc1
I did everything you asked but it's not working.One minute after I open the computer the bug happen.
